installed tein basic dampers.... something went wrong
Old Apr 2, 2011 | 04:56 PM
redlinexd's Avatar
Default installed tein basic dampers.... something went wrong
after installing the teins today, i realized the front passenger side makes a ton of noise. I even looked at the top part, something went wrong. I don't know what happened but the passenger side sits higher on the top part of the spring. I bought these used from a friend who crashed his integra, but i installed them on a EG. The first picture is what it's suppose to look like, and the passenger side looks like that...
Old Apr 2, 2011 | 05:06 PM
Linked's Avatar
Default Re: installed tein basic dampers.... something went wrong
looks like your tophat is broken, that bushing is suppose to sit in the tophat, the noise is probably the strut hitting the hood or something
Old Apr 2, 2011 | 05:17 PM
redlinexd's Avatar
Does anyone know where I can buy tophats? OEM or aftermarket? I saw a diagram of what I need to replace and I need # 6,9, 12, and possibly 7.
Here is the link to the diagram. https://www.hondapartsdeals.com/imag...S020.010.2.gif
Old Apr 2, 2011 | 07:21 PM
94EG8's Avatar
Seagull Management
Tophat is probably fine, but the thick washer that goes underneath is bad. You'll have to take the shock/spring assembly apart and replace the washer, #13 in the diagram.
Old Apr 2, 2011 | 07:51 PM
NotAJDMFanBoy's Avatar
I remember on my Konis that the shaft was stepped down at the threads and the washer had to go on that step before putting the collar on that went through the two bushings.
Easy mistake, easy fix. No harm done.
Old Apr 2, 2011 | 07:54 PM
ifIexplode's Avatar
Was just comin in here to say the same thing.
JDM-sol 89's Avatar
I agree, has happened to me.
Old Apr 2, 2011 | 09:14 PM
redlinexd's Avatar
i dont remember seeing #13 in my dampers, is that for a stock strut?
Old Apr 2, 2011 | 09:22 PM
redlinexd's Avatar
I'm using a diagram from the tein website now and on page 8 which one am I suppose to replace? The thick washer meaning the rubber? or the tiny O-ring looking washers?
Old Apr 3, 2011 | 04:08 AM
94EG8's Avatar
Seagull Management
You have to reuse it when using aftermarket shocks generally. I just installed 2 new tokico blues on my 4 door this week and had to reuse the old washers.
Old Apr 3, 2011 | 04:23 PM
redlinexd's Avatar
okay ill try and get this all figured out this week and show u guys the aftermath. hopefully it's just the bushings and stuff. This link may have solved my problems, ill take apart the top hat and see if everything is lined up in place.
http://www.d-series.org/forums/diy-f...ck-travel.html
Old Apr 3, 2011 | 05:11 PM
jserman's Avatar
I did the same thing when installing my buddy clubs. you just forgot the washer on the bottom of the top hat.. simple fix
check this thread it explains it
https://honda-tech.com/forums/suspension-brakes-54/koni-yellows-gc-using-oem-top-mounts-something-very-wrong-2902104/
Old Apr 3, 2011 | 05:46 PM
5OHinaEK's Avatar
yup .. Ya gotta reuse those washers.. Its - strut/washer/rubber/hat/rubber/washer/bolt... More or less
Old Apr 3, 2011 | 05:59 PM
JDM B20 EH2's Avatar
Its that washer. Have had the same prob on a Eclipse in the past. Bad thing on that car is it got into the hood.
Old Apr 3, 2011 | 06:12 PM
redlinexd's Avatar
I might have to buy some of these, might as well buy a pair and replace both fronts. I looked closer on the passenger side and the rubber is torn. what do u guys think of energy suspension?
http://www.energysuspensionparts.com...rod=MOOG-K9492
Old Apr 3, 2011 | 06:26 PM
5OHinaEK's Avatar
very good stuff in poly. But squeaky. You gotta grease them. .............your link is for moog . On the ES site. Moog is stock replacement rubber. The best stock replacement.
Old Apr 4, 2011 | 10:42 AM
redlinexd's Avatar
Guys, I just found out that the diagram that I used previously isn't from an integra! no wonder I was confused with the #13. According to this diagram that I put on this reply, it was #7 and #14 that need replacing, the top #7 is ripped and the bottom #7 isn't even there! and #14 is splitting in half. According to this diagram, I think I can snag these from a honda dealership.
Last edited by redlinexd; Apr 4, 2011 at 11:02 AM. Reason: This diagram is for the INTEGRA (correct one)
Old Apr 4, 2011 | 10:59 AM
TheHatchMan's Avatar
TRW for replacement bushings and suspension related items very impressed with the quality.
Old Apr 6, 2011 | 07:30 PM
redlinexd's Avatar
The aftermath: The top hat was broken (part of the inner piece chipped right off), the collar that goes through the rubbers is bent, one of the washer's rings went from a circle shape to an oval shape, the top rubber is messed up AND the bottom rubber that goes under the top hat is missing! my friend must've hit something HARD during his accident, but other than that, everything turned out great.
jerm__
Honda Civic (2001 - 2005)
13
Jun 14, 2010 08:02 AM
vlude99
Oct 4, 2009 03:09 PM
alscrx
22
Jul 8, 2008 02:46 PM
tridim
Suspension & Brakes
Jun 26, 2007 04:07 PM
jay_type-s
Apr 2, 2006 05:34 PM
