TONS of PARTS! B-series, turbo, Ls, GSR head, Built, Wiriing harness,starters
Rest of the stuff
Stock flywheel-$30
Polyurethane home made motor mounts-$50
Brand New Autozone starter-$80
Turbo piping
Turbo stuff
Full exhaust for a eg hatch-$100
T3/T4 turbo-$100
Other honda stufff
P72 pistons and rods $50
Brand new block Guard $80
B16a stock block w/ block guard $200
pm for specific prices or email at tylerdurtan007@yahoo.com
Sold Items
*SOLD*P72 GSR head
*SOLD*Vector X intake Manifold
*SOLD*Moroso oil Pan
*SOLD*ACT stage 3, 6 puck clutch
*SOLD*P-28 ecu-$80
*SOLD*P-13 at ecu $80
*SOLD*Tubular manifold -$70
*SOLD*38mm Tial style wastegate ($50)
*SOLD*Aluminum B series pulleys $40
*SOLD*3Bar GM map sensor $45
*SOLD*LS oil pickup $10
*SOLD*Skunk 2 Titanium Retainers
*SOLD*SAFC $100
*SOLD*Ls bottom end
*SOLD*stock axles
*SOLD*800cc Bosch injectors
*SOLD*New Honda time belt
*SOLD*New Honda oil filter
Stock flywheel-$30
Turbo piping
Turbo stuff
T3/T4 turbo-$100
Other honda stufff
Sold Items
*SOLD*P72 GSR head
*SOLD*P-28 ecu-$80
*SOLD*SAFC $100
*SOLD*Ls bottom end
*SOLD*stock axles
[IMG]
[/IMG]
B16A $300 with block guard. Motor was working fine but a guy took the head to build an Ls Vtec motor. Cylinder walls need to be cleaned up
[/IMG]B16A $300 with block guard. Motor was working fine but a guy took the head to build an Ls Vtec motor. Cylinder walls need to be cleaned up
This is a MSD blaster Coil 2 --------$30
I have two honda engine harnesses both are unknown make and model but most likely OBD1 harnesses. They look like they both have vtec plugs
Here's two fuel rails both for a b-serises the red one is HAYAME performance FR-1 $60 and the other is a no name.
3 Boost gauges the blacked out one goes to 20psi ($30) the regular colored ones go to 30 psi($40). I will be keeping one of the 30 psi gauges. $45 each
Rsx rim -$80 rim in good condition only slight marks on one of the spokes
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
