vss question
Old Apr 2, 2011 | 08:34 AM
tominos's Avatar
Default vss question
so my buddy has a jdm rhd crx. his cel came on and flashed 17 times, which is supposed to indicate a vss problem? if we were to buy a vss, can i use a us part( he has a zc in there, probably a zc tranny too) or does it have to be the japanese equivalent? his speedometer reads in km if that makes a difference.
Old Apr 6, 2011 | 03:52 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: vss question
The electrical part of the VSS is in the gauge cluster. I would guess there may just be a continuity issue with that wire to the ECU. if the vss itself is bad, the only solution i am aware of is to replace the gauge cluster.
Is the speedometer working? if it is not, then the transmission cable probably broke.
gwchndlr
Mar 20, 2007 03:20 PM
Jay.D.Em!
Mar 15, 2006 04:34 AM
SHJR89CR-X
Feb 23, 2006 06:49 PM
QWKPHKR
Dec 23, 2001 05:47 PM
