????? b16a converted to obd2 into 2000 em1
hey I know this is probably been cleared alot of times but can't seem to find any info and if I do find something about it, people are using 96-2000 ex harness on there b16 EKs and I've heard it's better to use the ex harness than the original em1 b16a2 engine harness.
I guess my question is can I use the original em1 engine harness without any extra wiring and problems??? I will be doing a jumper harness obd2 to obd1 and use my p28 ecu thanx in advance
Yes, using an em1 harness makes the install plug and play as long as you have an obdII distributor with the B16A as well as the ecu jumper
jaelynrei
13
Sep 15, 2014 10:53 AM
endlessdv
Feb 6, 2005 04:16 PM
Charlie Moua
Sep 25, 2003 04:19 AM
