CFK Issue-96 Integra ls
Old Apr 1, 2011 | 10:27 PM
Chrisdc2's Avatar
Default CFK Issue-96 Integra ls
what's up, I been trying to chase this problem and I'm not sure what it could be. the car used to have an obd1 sprocket, obd1 p75, and no CFK,I have put the sensor I have put the OBD2 sprocket, replaced the ecu to obd2 p75 a02 , I'm not sure if I'm missing anything, and I still get the Check engine. btw I have a 97 gsr harness in it. any advice thanks.
Old Apr 1, 2011 | 10:54 PM
mark@silbernage's Avatar
Default Re: CFK Issue-96 Integra ls
What code are you getting?
Old Apr 2, 2011 | 08:24 AM
Chrisdc2's Avatar
P1337
Old Apr 2, 2011 | 09:43 AM
mouab18c1's Avatar
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
Old Apr 2, 2011 | 10:26 AM
Well.. double check that the sensor is the correct one for that ECU, and trace the wires to be sure the signal is making it to the right pin. Easiest with two people... Double check that the gap appears appropriate between the sensor and the teeth on the pulley - mounting hardware for it seem to line up and bolt down 'right'?
My JDM (for example) doesn't have the part of the crank pulley with the teeth for the CKF.
Old Apr 2, 2011 | 11:15 AM
Chrisdc2's Avatar
Yeah everything lines up, it's mounted where it should be, but I'm going to check to see if the sensor is even getting any current or if it's giving out any signal. And I'll update if anything, hopefully the sensor is just bad and not the wiring. Thanks I'll update after I check it
Old Apr 2, 2011 | 08:50 PM
I think the pickup is essentially an inductor (coil) wrapped around an iron core so that the teeth on the pulley disrupt the magnetic field and produce an electrical pulse the ECU can detect. I don't know what the resting impedance is, but if you have a decent ohmmeter you should be able to confirm that same (or very close) resistance reading back at the ECU connectors.
Good luck
Old Apr 3, 2011 | 04:33 PM
DC2_Legend's Avatar
theres a cfk bypass mod somewhere on the net, gl.
Old Apr 3, 2011 | 09:59 PM
http://www.ff-squad.com/technet/ckftrick.htm
Here's one.. you can use the signals from the distributor to convince the ECU there's a happy CKF..
FYI
brenaj
Apr 8, 2018 11:34 AM
joshd_bh
Sep 5, 2012 08:14 PM
darksolguy
10
Jul 14, 2008 06:19 PM
cheeks97R
Apr 17, 2005 09:22 AM
gotjesus
Nov 7, 2003 09:03 PM
