thermostat housing sending unit
if i replace the existing sending unit with a aftermarket gauge sending unit will it mess with my ecu or cooling fans, cause i replaced it and my car started running rough and then i put the stock one back in and it was fine confused.
right on thanks. but i am still sceptical on where i should put the sending unit cause i cant find a open spot on the block like i did for the oil pressure gauge...
Correct! The temp gauge sending unit is the single wire unit located in the head under the distributor. If you are wiring up aftermarket gauge this is the sending unit you want. Not the fan control units on the thermostat housing and upper rad hose.
thanks that what i thought to do it at but my good bud said that you cant do it with that one so thats why i tried the housing unit so thanks again you all
