Wilwood billet dyna lite calipers
I have a set of Wilwood billet dyna lite calipers from the Integra(all) kit... calipers are complete and in good condition but they need to be rebuilt. rebuild kits are very very cheap(o rings is about it). I also have a set of new hangers from the kit and a set of rotor hats from the same kit... shoot me an offer for the lot or by the piece.
Schu
MSchu18@yahoo.com
Schu
MSchu18@yahoo.com
I have a nearly complete Acura Integra Wilwood four piston Big Brake kit for sale... the only thing missing are the rotors , which you can get from many online sellers, and the brake pads. they come with a set of used (need to be rebuilt) Billet Dyna Lite calipers, Aluminum rotor hats, stainless steel brake lines, and the hard to find Steel Hanger/caliper mounts. I also have the rebuild kit that will come with the calipers. everything else is new on this kit except the calipers and they are in great condition as are the caliper pistons. most parts are interchangeable with the Honda civic.
looking to get 275 obo for the kit
Mounatins edge area
Info:
Brand Wilwood Disc Brakes
Manufacturer's Part Number 140-6163-D
Part Type Disc Brake Kits
Product Line Wilwood Dynalite Big Brake Front Disc Brake Kits
Position Front
Disc Brake Kit Type Manual
Front Rotor Included Yes
Front Rotor Style Cross-drilled/Slotted surface
Front Rotor Construction Vented
Front Rotor Diameter 12.19 in./309.6mm
Front Rotor Thickness 0.81 in.
Rear Rotor Included No
Front Caliper Included Yes
Front Caliper Piston Quantity Four
Front Caliper Material Aluminum
Front Caliper Finish Black anodized
Rear Caliper Included No
Parking Brake Provision No
Minimum Recommended Wheel Diameter (in) 17 in.
Front Spindles Included No
Master Cylinder Included No
Brake Booster Included No
Brake Lines Included No
Quantity Sold as a kit.
Notes Fits 4-lug, 262mm OE rotor.
Get track-ready performance and high-tech style with Dynalite Big Brake front disc brake kits from Wilwood. These competition brake kits are loaded with cutting-edge technology and provide the perfect look when upgrading your wheels, tires, or suspension. Each kit is a complete bolt-on, with no need to modify the stock brake or suspension components.
Mounatins edge area
Info:
Position Front
No type r... 4 lug INTEGRAS... Pictures? it's the same set up described above.. pretty standard fair. everything is new except for the calipers which just need the o rings replaced(which I have.)
how did i know you were gonna do that. i wanted actual pics of them not a generic picture of what they looked like when new. but i guess that'll do.
