D16 parts... EF,EG.... and many more
Old Apr 1, 2011 | 04:32 AM
jaycorolla's Avatar
Default D16 parts... EF,EG.... and many more
For Sale...........
VX black box... $40 ..... this is the black box that is on fire wall needed for swap....
(EF) center console face.. where climate control goes and head unit.... $20
94 integra armrest.... asking $35
pm5/6 distributor cap... $5
(6) oem/ aftermarket gas caps... $5 each
(1) set of EF spark plug wires NGK..... $10
(1) set of EF spark plug wires Bosch .... $7
(1) mini k&n filter... $20
(1) d-series exhaust gasket... metal... $5
(3) 88-91 factory headlight retainer clips.... $5 each
(1) EF d16 map sensor.... $30
(2) washer fluid blue caps....$5
(1) 90 Honda Civic map sensor w/ purge cut solenoid unit..... $35
2530 prop valve.... $20
(4) pairs of windows cranks... $10 pair or....$5 each
(3) stock 5speed shifter ***** $5 each
(1) sets of 88-91 civic oem battery tie down... $10
(1) pair civic/ crx door locks .... $50
(2) pair of windshield wiper arms...... $20 a pair
(1) rear ash tray for civic...... $5 each
(3) dome light units..... $15
(1) rear view mirror... $ 20
(5) corner dash vents.... $5 each
(4) visors... 2 driver .... 2 passenger.... $5 each
(2) front windshield wiper motors.....$30 each
(1) rear windshield wiper motor ...... $30
(3) door handle inside cover....$10 each
(2) dash change pocket... $15 each
(1) small dash compartment pocket .......$10
Rear brake tail light housing and cover... perfect condition..... $10
(2) ignition wire harness... $25 each
(1) passenger side vent.... for (EF) dash...... $10
(1) crx corner rear glass peice... the small triangle piece..... $10
(1) interior fuse pannel cover... $5
(2) passenger grab bar... $5 each
(1) IACV for d16z6..... $30
(1) 88-91 Civic * HATCHBACK COWL PANEL WIPER COVER TRIM *EF.... $40
(2) main engine fuse box for EF......... $25
(2) pairs of EF hood hinges...... $15 a pair
y8 computer... p2p ecu... $50 or obo
i have a intercooler..... $30 obo.... good lentgh... worked well for 250 hp application...
88-91 civic hatch back rear glass panels... pair..$60
D16Y8 AEM fuel pressure regulator.... $70
D16 Vortech (8F103-045) high flow fuel rail...(very rare and hard to find.... new they are asking $200 with shipping).... $80 or obo
D16 Holley (534-87) high flow fuel rail.... $60 or obo
D16 AEM fuel filter... $25
Brand New Supertech Bronze Valve Guides (16)........ $50
Supertech valve springs for D16z6 or y8 heads... $100
BLOX titanium retainers for d16z6 or y8 in box (only was used for less than 1000 miles)..... $120 or OBO
correct passenger and driver side mirrors for crx/civic hatch..... $35 each or obo
civic hatch climate control unit with A/C button.... $55 or obo
civic hatch A/C cooling unit that is inside the car cabin..... $75 or obo
civic hatch heat blower unit that is inside car.... asking $65 or obo
civic hatch time clock on dash.... $20 or obo
310cc dsm injectors.... $45 or obo
88-91 civic hatch attenna... $25
i also have a bunch of window cranks and those plastic washer things that go in between the crank and the door panel.... asking $5 for pair of washers, also $5 for window cranks
CROWER D16y8 stage 2 N/A cam.... can also be used in Z6 head w/ cam gear..... asking 200 or obo
JDM ZC DOHC full motor....30k to 40k on motor...... ready to be installed... has dizzy and ecu..... everything $600
D16Z6 rebuilt bottom end (short block)... fully rebuilt, never been ran... had new crank that has been polished and balanced with rods....block has been honed out... 75mm.... has stock rods and pistons with new rings, new oil pump, new water pump, blue gates timing belt, new gaskets, new rods bearing n crank bearings, also has new alternator belt with alternator... asking $300 or obo ....(local pick up or delivery only) this short block has 0 miles on it... all you need is a head and its ready to be driven....
i have many other parts...all sizes from fuses... relays... sensors... main relays...to most body pannels, glass or other things just send me a pm or email for anything you can think that i havent listed...
also have pictures upon request.. when asking send email address or cell number to send pics
Old Apr 1, 2011 | 08:12 PM
jaycorolla's Avatar
Default Re: D16 parts... EF,EG.... and many more
many parts here
Old Apr 1, 2011 | 08:53 PM
ApexiChild's Avatar
what color?
black blue red?
Old Apr 1, 2011 | 08:56 PM
1990CRXSIJDMEF8's Avatar
bump where u at?
Old Apr 1, 2011 | 09:17 PM
redef90si's Avatar
post pictures
Old Apr 3, 2011 | 07:40 PM
jaycorolla's Avatar
bump
Old Apr 3, 2011 | 11:51 PM
v8killaz's Avatar
what year is this from
if its 99-00 pm me
Old Apr 4, 2011 | 09:31 AM
earlehd's Avatar
PM'd on mirror
Old Apr 4, 2011 | 11:38 PM
jaycorolla's Avatar
up
Old Apr 5, 2011 | 11:35 AM
kaliboy562's Avatar
pm for purge IACV
Old Apr 5, 2011 | 01:03 PM
macef9's Avatar
bump
Old Apr 6, 2011 | 04:51 AM
jaycorolla's Avatar
bump
Old Apr 6, 2011 | 05:23 AM
hugens26's Avatar
I'll give you 35 for the ecu
Old Apr 7, 2011 | 04:44 PM
jaycorolla's Avatar
b u m p
Old Apr 10, 2011 | 09:43 AM
jaycorolla's Avatar
ump
Old Apr 13, 2011 | 03:24 PM
jaycorolla's Avatar
parts!!!!
Old Apr 13, 2011 | 07:30 PM
rusty_34610's Avatar
Still have the ecu ? if so pm me please
Old Apr 25, 2011 | 09:23 PM
jaycorolla's Avatar
bump
Old Apr 27, 2011 | 06:34 PM
jaycorolla's Avatar
bump
Old Apr 30, 2011 | 08:27 PM
jaycorolla's Avatar
bump
Old May 1, 2011 | 10:19 AM
TORQUE MONSTER's Avatar
Please post pics of the CRX bumper and the Z6 head.
thanks!
oe
Old May 8, 2011 | 06:43 AM
jaycorolla's Avatar
bump
Old May 18, 2011 | 07:36 AM
jaycorolla's Avatar
bump
Old May 18, 2011 | 11:17 PM
Chinois's Avatar
What year is the CRX Bumper off of?
Old May 25, 2011 | 06:53 AM
jaycorolla's Avatar
bump
