I'm trying to figure out my compression ratio
Old Mar 31, 2011 | 10:27 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default I'm trying to figure out my compression ratio
Using this C/R Calc ---> http://www.summitracing.com/expertad...sionCalculator
I'm not sure what to put for my
(Deck Clearance) and (Compressed Gasket Thickness)
Engine is 2001 B18C1
Here is what I have for the other
Bore: (diameter) 81.5mm
Stroke: 87.2mm
Cylinder Head Volume: 41.6cc
Effective Dome Volume: +7.70cc
Deck Clearance: ???????
Compressed Gasket Thickness: ??????
Number of Cylinders: 4
Here are the pistons I'm looking to use.
http://www.summitracing.com/parts/PBP-11885-50/
Old Apr 1, 2011 | 07:29 AM
96 GSR-T's Avatar
Default Re: I'm trying to figure out my compression ratio
http://www.zealautowerks.com/bseries.html
Not that there is anything wrong with what you are doing, but ordering engine internals for your Honda from Summit is kinda
CP, Wiseco, Arias, Manley, JE all make good pistons for your car.
Old Apr 1, 2011 | 07:38 AM
No-Traction = Fun
Hahaha yeah Roger that. here are the other 2 Im looking at
SuperTech # P4-H815-N2
http://cgi.ebay.com/ebaymotors/Super...#ht_2450wt_939
Or
Arias # 3320200
http://www.anclamotorsports.com/aria.../i-259699.aspx
Old Apr 1, 2011 | 07:48 AM
wantboost's Avatar
Who is Mr Robot?
lol, yea the compression calculator that gsr posted is by far the most informed and accurate.
also look into mahle. they make awesome parts
Old Apr 1, 2011 | 07:52 AM
96 GSR-T's Avatar
With a stock headgasket and .020 taken off the head and block you will be at 9:1 on the dot with the Arias link you listed.
Old Apr 1, 2011 | 08:06 AM
No-Traction = Fun
9:1 on 15lbs of boost, would that give me 350 true wheel HP?
Old Apr 1, 2011 | 08:07 AM
96 GSR-T's Avatar
Without knowing what turbo I cant really help you, on a GSR typically yes unless your running something really small.
Old Apr 1, 2011 | 08:26 AM
No-Traction = Fun
Bore 81.5 (mm)
Stroke 87.20 (mm)
Deck Height 212.39 (mm)
Head
B18C1
Combustion Chamber Volume 41.60 (cc)
Piston
Arias # 3320200
Dome -.10 (cc) Comp Height 30.099 (mm)
Connecting Rod
Eagle
Rod Length 137.90 (mm)
Headgasket Thickness
OEM 3-layer
Thickness 0.026 (in) Bore diff (mm) *
Head Milling and Block Decking
Enter total amount head has been milled and block decked 0.20(in)
Maximum Operating RPM 8500 (rpm)
Elevation 2600(feet)
Boost 15 (psi)
Static Comp Ratio 9.05: 1
Effective Comp Ratio 17.23:1
Displacement 1819.62 Cc
Rod / Stroke Ratio 1.58:1
Piston-to-Deck Height 0.011in
Mean Piston Speed 2051 fps
Max Piston Acceleration 149170 fps2
Old Apr 1, 2011 | 10:58 AM
wantboost's Avatar
Who is Mr Robot?
You're gonna hate that eBay turbo. Not to mention it has a t04b wheel so it's gonna make shitty power.
Old Apr 6, 2011 | 03:12 PM
No-Traction = Fun
Oh really? what are the pros: and cons:
I got the turbo for a trade.
Old Apr 6, 2011 | 06:17 PM
96 GSR-T's Avatar
Cons: its a POS made in china, it will spool fast and them quickly fall of its face and stay there.
Pro's: IDK of any lol
Old Apr 6, 2011 | 07:54 PM
wantboost's Avatar
Who is Mr Robot?
what he said... basically
Old Apr 7, 2011 | 06:09 PM
No-Traction = Fun
oh well, it was free. maybe Ill use it during engine brake in and then replace it with a real turbo.
Old Apr 13, 2011 | 07:34 AM
No-Traction = Fun
How about this turbo? Will this be too big for a daily driver?
http://cgi.ebay.com/ebaymotors/Preci...#ht_5773wt_937
Old Apr 13, 2011 | 08:54 AM
4cylfiend's Avatar
That thing will be wayy to lazy with a exhaust housing of .82. It would still be slightly large even in a .63 exhaust housing but not bad if you decide to run more power. Look into a precision 5857 with an a/r .63 exhaust and an a/r .60 compressor housing. You will have a much more usable powerband. I ran that on my gsr and I make 400 on 16lbs using 93 oct. Mine was even a cast wheel journal bearing 5857.
Old Apr 14, 2011 | 07:37 AM
No-Traction = Fun
What about the Holset turbos? I heard those can make good power and the spool super quick.
Old Apr 14, 2011 | 08:02 AM
4cylfiend's Avatar
personally Id stick with a Precision or a Garett. I just got my mine in the mail yesterday.
Old Apr 14, 2011 | 08:15 AM
No-Traction = Fun
Is that your turbo in the picture? What is the rating on that one? how is the spool time and power range?
Old Apr 14, 2011 | 08:39 AM
4cylfiend's Avatar
Ya its mine. Its a billet 6262. It has a .82 a/r exhaust and a .70 a/r compressor cover. Its rated to the 700whp range, but I know alot of ppl who have made 750-800 on them. This will not be a effecient turbo for your setup. The powerband will be useless.
Old Jun 11, 2011 | 09:01 AM
No-Traction = Fun
Am I doing something wrong here? Is this CR going to be too low?
Block
B18C1
Bore 81.5(mm)
Stroke 87.2 (mm)
Crank B18C1 (GSR) Year 2001
Head
B18C1 Combustion Chamber Volume 41.66 (cc)
Piston Wiesco 81.5mm
Dome -12(cc)
Comp Height 30(mm)
Connecting Rod Eagle
Rod Length 137.998(mm)
Headgasket Thickness Cometic 3-layer 81.5mm Thickness .027"(in)
Bore diff 0.00(mm) <-----NOT SURE
Total amount head has been milled and block decked <---NOT SURE
RPM Redline 9000
Elevation 2600 ft
Boost 5-16psi
Static Comp Ratio
8.63:1
Old Jun 11, 2011 | 03:35 PM
No-Traction = Fun
Can anyone chime in? am I doing it right? See above
Old Jun 11, 2011 | 04:11 PM
racebum's Avatar
if you smooth the chamber you'll have more than 41.6ccs also depends on what valves you use. personally i'm all about oem or ferrera.
piston wise, i really don't see a reason to build a 9:1 street engine
if you use the ferrera dished valves and shave the deck and block to being true along with an oem head gasket you should fall right around 10:1-1 to 10:5-1 with the below piston, it really all depends on how you work the combustion chamber and how much winds up being shaved
http://cgi.ebay.com/ebaymotors/MAHLE...item359cbed057
Old Jun 11, 2011 | 06:49 PM
No-Traction = Fun
Sorry I already got my pistions. Wiesco
http://www.importparts.com/shop/prod...oducts_id=5994
Old Jun 11, 2011 | 09:05 PM
racebum's Avatar
ahh.. those are dished. it will work, just will require more pressure than a flat top.
Old Jun 11, 2011 | 09:10 PM
No-Traction = Fun
More Boost?? I like the sound of that
xander1100
Nov 29, 2008 07:13 AM
NathanMorris
Jul 28, 2006 05:59 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
itr_18
Apr 8, 2004 06:10 AM
