EVERY SINGLE THING IS BEST OFFER!!!! Garage Cleanout! B&D SERIES. Endyn. B20b block
Old Mar 31, 2011 | 04:38 PM
C16efsedan's Avatar
Default EVERY SINGLE THING IS BEST OFFER!!!! Hasport! B&D SERIES! Endyn! B20b block.
Means of contact: PM on here or 804-337-8376
Price: $ Best offer on everything.
Description: Garage Cleanout!!!
CHEAP CHEAP CHEAP!!!!
I need this stuff gone!
Things will continue to get added as I tear down some of my vehicles
Lots of good quality parts need to get to good homes!
Pictures:
SOLD - Hasport 88-91 Civic/CRX Billet Mount Kit for B series with Hydraulic Transmission and also the Cable to Hydraulic Conversion brackets. 88 Urethane Stiffness.
D15b2 Original Engine Out of my sedan with trans and linkage. 209,000miles. Minor Smoke.
EF Radiator
NEW (Not Refurb) Axles purchased from a local auto parts store used for a month then decided to go b series. Still have the boxes.
Used Axles. Still in good condition. No rips or tears. For D Series
LS OBD0 ECU. Perfect condition.
Drilled Rotors. They Fit Dx, Cx, lx
Endyn Crankcase Ventilation Kit
Obd0 Alternator
Starter Unknown Condition (i think solonoid was bad)
Autometer Phantom Tach
GSR Distributor (Needs cap replaced and to be repinned) Works Perfect.
GSR Timing Belt
Brake Boosters. One EF and One DA. Picture is of a DA 15/16ths
LS Oil Pan, pickup, and windage tray.
B20 Block with cracked sleeve.
Panasonic Radio
GSR Water Pump. Purchased new from acura and only used for 15k miles
EF Steering wheels
EF Airbox with new filter
DA prop valve
EF Master Cylinder (2)
Chrysler OEM Newer Style Radio
Chrysler OEM Older Style Radio
Old Apr 1, 2011 | 08:16 AM
C16efsedan's Avatar
Default Re: EVERY SINGLE THING IS BEST OFFER!!!! Garage Cleanout! B&D SERIES. Endyn. B20b blo
bump
Old Apr 4, 2011 | 11:44 AM
C16efsedan's Avatar
bump
Old Apr 5, 2011 | 07:30 AM
C16efsedan's Avatar
bump
Old Apr 6, 2011 | 06:16 AM
C16efsedan's Avatar
bump
Old Apr 7, 2011 | 11:49 AM
C16efsedan's Avatar
bump
Old Apr 7, 2011 | 11:57 AM
dc2JDMwhore's Avatar
$10 shipped for the GSR oil pickup to 73703? lol
Old Apr 7, 2011 | 12:59 PM
C16efsedan's Avatar
If i can ship it for less than that then sure.
Old Apr 8, 2011 | 06:23 AM
C16efsedan's Avatar
bump
Old Apr 11, 2011 | 06:12 AM
C16efsedan's Avatar
bump
Old Apr 12, 2011 | 05:24 AM
C16efsedan's Avatar
bump
Old Apr 13, 2011 | 12:38 PM
C16efsedan's Avatar
bump
Old Apr 14, 2011 | 04:46 AM
C16efsedan's Avatar
bump
Old Apr 15, 2011 | 08:03 AM
C16efsedan's Avatar
bump
Old Apr 15, 2011 | 10:52 AM
get RIGHT's Avatar
$40 shipped on the Endyn?
Old Apr 16, 2011 | 07:43 AM
C16efsedan's Avatar
bump
Old Apr 18, 2011 | 04:29 AM
C16efsedan's Avatar
bump
Old Apr 20, 2011 | 05:37 AM
C16efsedan's Avatar
bump
Old Apr 21, 2011 | 10:00 AM
C16efsedan's Avatar
bump
Old Apr 25, 2011 | 12:46 PM
Dancing is Forbidden's Avatar
what shape is that d series tranny in? How much if I come pick it up? I live at Snowshoe and travel to VB regularly.
Old Apr 25, 2011 | 03:52 PM
Black-Ty [EG6]'s Avatar
bump
Old Apr 25, 2011 | 08:09 PM
C16efsedan's Avatar
I drove it pretty easy considering the d wasnt the most powerful thing in the world. Only had minor grind at high rpm two or three times I took it close. Not sure if it was the cable not being adjusted or the linkage. I can crack it open for serious buyers.
Old Apr 25, 2011 | 08:22 PM
crx_si-r's Avatar
how much you looking to get for the gsr distributor? lmk
916-541-5266
Old Apr 26, 2011 | 08:53 AM
C16efsedan's Avatar
Mounts SOLD!
Old Apr 28, 2011 | 06:45 AM
C16efsedan's Avatar
bump
