Clifford Matrix 3.3x How to Adjust Alarm Noise
Hey guys I have a clifford Matrix 3.3X and I was wondering how to adjust noise on alarm. My sirens are really low and there not heard a t all from a distance. I want to raise volume for siren and when I lock and unlock you could barely hear the "Chirps" any ideas or tips?
Not sure about the Matrix.. but I know some of the older (I haven't done a newer DEI alarm in a while so not sure about the new ones) had two black loops on the siren.. one you'd cut so it'd only do one siren tone (instead of the various sounds), and one you could cut to "mute" the siren IIRC... or it was cut to make louder, I forget. It's been too long.
see attached file for the loop to cut. keep in mind this only increases your arm/disarm chirp. if you're full trigger volume is low, make sure your ground is clean and voltage drop free, and that the siren opening is not obstructed.
hope this helps.
hope this helps.
teejlc
Audio / Security / Video
19
Nov 6, 2007 01:44 PM
