FS: EG black drivers door shell, pass window, si door panels
pm me and ill get back to you with my number or pm me your number
i will not meet you anywhere besides my house or northgate mall
prices too low to lower
Ebay EF right amber corner light, will only fit 90-91 ef hatch. trust me it won't fit an 89 or earlier. new never used
-$5
passenger window glass i even cleaned it for you
-$10
eg si door panels (door panels with pocket)
long *** fyi:
- si and ex door panels have the pocket at the bottom,
- if you have a dx/cx and want the pocket you can use either si or ex door panel
- if you have a dx/cx and want the pockets and are going to stay with manual window/locks you need to find si door panels because the ex panels are cut for lock switch, also on the fabric part the hole is bigger for window control switches.
- if you are upgrading to electric (big pain) then ex door panels will do
- since you are not upgrading to electric you should buy these and enjoy the pockets and rewrap them in a fabric of your choice. half the work is done for you.
these are drilled out because i wanted to get itr seats and wrap the door panels in similar material but lost motivation and no money for itr seats
these fabric part of these were cut out PERFECTLY and are ready to be rewrapped.
the door panels are not mint but you can use them if you are trying to change to black.
if you have good condition panels then drill yours out and put these in.
just make sure you leave enough plastic so you can either screw these in with a screw/washer, or simply melt them
anyways here are some diy links for rewrapping door panels you will see what im talking about.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-eg-door-panel-recover-cloth-wannabe-leather-883815/
http://www.ht-archive.com/showthread.php?t=2638652
so included is the door panel, fabric part that is cut out, all the plastic pockets, screws, and also manual window handle, and speaker covers, the actual door panel has two clips broken on the backside
-$20
-$5
-$10
long *** fyi:
-$20
