92 Accord Torque Converter Failing?
Old Mar 31, 2011 | 07:53 AM
tiresias's Avatar
Default 92 Accord Torque Converter Failing?
I have a 92 Accord I got as a gift for graduating and am now in college. It came with an auto tranny.
Since I got the car, I noticed that the car wont shift into gears. It simply stayed in first gear all day. ALSO, the car has an extremely slow take-off while in "D." It's slow like a worn down clutch in a MT car trying to peel off.
My mechanic thought it was those solenoids but after my 6th pair from the junkyard, I decided to get new ones and it failed utterly. Could it be the torque converter that is the issue or do I need a new transmission?
Any help would be greatly appreciated. I'm wasting too much money trying to get this SOB fixed.
Old Mar 31, 2011 | 08:06 AM
(. )( .)'s Avatar
Default Re: 92 Accord Torque Converter Failing?
check the fluid. if its low that will cause it not to shift. your transmission is hydromechanical it needs fluid to function. if the fluid is dark, drain nd refill, its not worth have the tranny pressurized to fully drain the system.
also, you can try a automatic trans shift additive, they're cheap and i do think they work.
Old Mar 31, 2011 | 08:18 AM
phootbag's Avatar
It is possible the TCM ( trans computer ) is not commanding a shift from 1st while in D4.
Also, it needs to be understood that most of what happens happens inside the transmission. There are a bunch of check valves, fluid ports, pressure activated valves and a bunch of other mechanisms that must work completely and flawlessly for the transmission to function properly. It's like an orchestra with one out-of-tune violin. It ruins the music.
Your transmission needs to be rebuilt or replaced.
Old Mar 31, 2011 | 09:33 AM
tiresias's Avatar
That's the first thing I did to try and solve the issue. I haven't tried any trans shift additives yet.
I do think I'll need a whole new tranny. It's acting like a little bitch--just like a whiny kid who needs to be dragged on the floor by his arm while showing no signs of resistance.
Will try the additive before actually committing to a new tranny. I just hope I can find a usable one on CL.
Old Mar 31, 2011 | 09:39 AM
phootbag's Avatar
There are wreckers out there who sell transmissions, among other parts, and offere warranties. I just had to buy one for my 94. Got it for 500 bucks with a 6 month warranty. Avoid CL. If it's for sale there it's because it's broken.
Old Mar 31, 2011 | 09:41 AM
tiresias's Avatar
Good point.
micahd02
Aug 3, 2018 12:44 PM
glenn380
Aug 16, 2011 10:04 PM
kadidle
May 12, 2009 03:17 AM
oscar_deuce
Dec 12, 2005 08:26 AM
screen designs
Dec 8, 2004 06:42 PM
