b16a2 ecu help!
Old Mar 31, 2011 | 12:33 AM
Ekay's Avatar
Default b16a2 ecu help!
ok i have a swapped b16a2 and the ecu. But In the car right now is just a sohc ecu, i have the ecu that came with the b16 and my question was can i just plug & play? or do i need to do anything to make it work?
-thanks
Old Mar 31, 2011 | 01:12 AM
First.EG's Avatar
Default Re: b16a2 ecu help!
i take it by your name that its going in an ek if the motor is obd1 then NO you will need a jumper harness
Old Mar 31, 2011 | 09:13 AM
Ekay's Avatar
o alright, well the car has everything from an em1 motor and all that stuff..would i still need a jumper harness?
Old Mar 31, 2011 | 09:57 AM
Sr420Det's Avatar
if its obd2 a ecu n a obd2 car than its plug n play, if its a obd 1 ecu n a obd2 car than u need a jumper harness.
Old Mar 31, 2011 | 10:41 AM
Ekay's Avatar
what would happen if i plug it in and its not the same? would the connections not fit? or would something short out?
Old Mar 31, 2011 | 10:47 AM
Sr420Det's Avatar
wont fit
Old Mar 31, 2011 | 11:02 AM
fallrivercolin's Avatar
b16a2 is an ob2 motor, your car is ob2... Should be plug and play
Old Mar 31, 2011 | 10:49 PM
Ekay's Avatar
thanks for the help guys, but i just asked the guy who i bought it from and he said i need a jumper harness. now another question.haha. how does a jumper harness work, and where can i get one? o and also lets say i get this jumper harness would i be able to BAR it and pass?
Old Mar 31, 2011 | 11:04 PM
Ekay's Avatar
which one would i be getting from here lets say? http://www.boomslang.us/obd2to2.htm
Old Mar 31, 2011 | 11:07 PM
Ekay's Avatar
the ecu i want to put in is a p2t. if that helps any..
Old Apr 1, 2011 | 09:28 AM
Ekay's Avatar
helpp
Old Apr 1, 2011 | 09:31 AM
redline1219's Avatar
Dude its simple. EM1 motor, OBD2 car, use OBD2 ecu from the em1. Plug and play.
Old Apr 1, 2011 | 11:18 AM
DAN!!!'s Avatar
There is obd2a which is 96-98, and obd2b is 99-00. what year is your car?
Old Apr 1, 2011 | 11:40 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
exactly. OP didn't post what kind of car he had. The EM1's ECU will plug into the 99-00 civic OBD2B harness no problems. But if the harness is OBD2A (96-98 civic), you need a different solution.
Old Apr 1, 2011 | 08:38 PM
Ekay's Avatar
sorry guys, my car is a 1996 and it has a 99 motor in it.
Old Apr 1, 2011 | 09:07 PM
Ekay's Avatar
here this might help out alot lol.. http://s19.photobucket.com/albums/b196/FOXBOY656/ekay/
Old Apr 1, 2011 | 10:09 PM
DAN!!!'s Avatar
u need a jumper harness. then it will plug right up.
Old Apr 1, 2011 | 11:00 PM
hatchet_honda's Avatar
doin engine swaps and dont even know the diff in ecus. gotta learn sometime i guess lol
Old Apr 2, 2011 | 01:42 AM
Ekay's Avatar
DAN!!! do you know what kind? lets say from here? http://www.boomslang.us/obd1to2.htm
hatchet i know im still learnin..
Old Apr 2, 2011 | 05:06 AM
B serious's Avatar
You need a jumper harness for an OBD2A car to a OBD2B ECU. Evasive had some good deals going with those a little bit ago. Got mine for $85
Old Apr 2, 2011 | 11:09 AM
Ekay's Avatar
alright cool thanks guys for the help, i know this is simple for you guys but im still in the learning process..
smiko0124
Jan 12, 2010 02:36 PM
ep3drvr
13
Apr 17, 2009 09:41 PM
ek coupe
Feb 19, 2009 09:05 AM
allaboutdaz
May 4, 2006 09:55 AM
sshaikh01
Mar 22, 2003 07:10 AM
