JDM B18c swap Crank position sensor?
Old Mar 30, 2011 | 06:03 PM
gsr-t9303's Avatar
Default JDM B18c swap Crank position sensor?
hey you guys im new. i swaped a obd2 b18c into my 2000 teg and i have no ckp sensor so i was wondering if the usdm ck sensor would fit in the jdm b18c? any help would be great.
thanks
Old Mar 30, 2011 | 09:45 PM
mark@silbernage's Avatar
Default Re: JDM B18c swap Crank position sensor?
Mounting for the sensor is part of the USDM oil pump, but not the JDM... so you have no mounting stud (etc) for it.
I don't know if there's an alternate mounting method that avoids changing the oil pump.
OTOH, there *is* a solution that takes the CPS signal from the distributor and fools the ECU into believing all is just fine. It seems to work well..
Details can be found here: http://www.ff-squad.com/technet/ckftrick.htm
...and here: http://ff-squad.com/wp/?p=309
The sensor's primary job appears to be to detect misfires - not as the sole source of information regarding crank position (that one's in the distributor).
Good luck
JAMN J
Sep 11, 2007 03:56 PM
98 gsr teggy
Apr 19, 2007 08:38 AM
swaplighter
May 31, 2004 03:49 AM
speedymon
Apr 25, 2003 10:43 PM
