FS// EG6KILIN ALL MOTOR B SERIES
like the title says so going a different route with this so now its time to let this go
i have a fully built b16a from HMO i have all the receipts to this motor
almost 6k invested in the motor everything is legit
here a couple of things done to the motor i also will give the buyer all the paperwork
ported and polished
3 angle valve job
omni springs
omni valves
omni retainers
buddy club cam gears
buddy club stage 3 cams
310 rc injectors
blox manifold
b20 throttle body
golden eagle fuel rail
blox fuel pressure regulator
steel braided fuel line with earl fitting
block
cosmetic high compression gasket
arp head stuts
polished crank
balanced crank
blocked been honed
ctr pistons (PCT oversized .25mm)
oem pistons rings
oem gasket kit
type r oil pump
oem timing belt
oem water pump
ctr crank pulley
alternator with aem pulley
there is couple thing i might be forgetting i dont have a price set right now but hey the worst i can say is no never got a chance to dyno the motor
(my girl told me its time to move on) me (yeah yeah yeah)
so my loss your gain guys if anything i will part out aslong i have a buyer for the head and block willing to ship at the buyers expense i will try to save you guys the most on shipping
NO PART OUTS ONLY FULL HEAD AND BLOCK
ported and polished
3 angle valve job
omni springs
omni valves
omni retainers
310 rc injectors
blox manifold
b20 throttle body
block
arp head stuts
polished crank
balanced crank
blocked been honed
oem pistons rings
oem gasket kit
type r oil pump
oem timing belt
oem water pump
ctr crank pulley
jDMJeRk
Aug 16, 2009 02:07 PM
