D.I.Y Fender Rolling
Old Mar 30, 2011 | 02:16 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default D.I.Y Fender Rolling
Fender rolling is very easy... just very time consuming. I beg you to take your time and do it right and everything with be A OK. First you'll need a fender roller and a heat gun
Take off your wheels and attached the roller to your hub and tighten her down.
Start by heating up the inner fenders until warm to the touch. It will take a couple minutes of heating before you start your rolling.
Then start with the wheel almost flat and make a couple of sweeps back and forth. You'll see the fender start to curve inward. Heat up the fender and repeat the process. As you do this start angling the roller upwards more and more to tuck in the lip.
Take your time and do it right... here is a video clip or two
Here is the final result!
Before...
After...
Old Apr 23, 2011 | 04:37 AM
b18c inside's Avatar
Default Re: D.I.Y Fender Rolling
Nice good write up!! Definitely going to be doing this to my car. Where did you buy the roller tool?
Old Apr 23, 2011 | 11:34 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Eastwood
Old Aug 7, 2011 | 09:44 AM
siimporter's Avatar
the video definitely helps to envision everything. Nice stuff
Old Aug 10, 2011 | 01:53 AM
azndoc's Avatar
Eastwood sells it and it is the most famous one or even power by max shop sells one as well.
Old Aug 30, 2011 | 09:06 PM
driveslowww's Avatar
good diy! Thanks
low_and_slow
Paint and Body
Mar 25, 2010 07:39 PM
i_VTEC
Sep 15, 2008 03:24 PM
Byaaah!
Paint and Body
Jul 24, 2007 10:44 AM
cilvia
Nov 16, 2005 06:47 AM
