D.I.Y Installing Cusco Bars and Harness Bars
So I bought some new goodies all at once... let me tell you I was sweating ***** trying to get these damn things in at the same time... what a pain in the *** but totally worth it!!
So lets see what I got in the mail!
What could that be?! :giggity::giggity:
First thing we need to do is take out the front and rear seats
Now we are going to undo all of the seat belt clips and harnesses
You will need to remove some of the spacers on the stock seatbelt bolt to fit with the new bars. I ended up removing a bunch because I'm rocking both cusco and NRG bar.
So start putting in the bars and figuring out the bolt lengths
Then I added the support bars and bolted everything down. From there I reinstalled the seats and bolts those back down.
I then stuck the harness threw and bolted the right side to where the stock seat belt arm was located, the left side went to the ground where the bottom seat belt tucks in and the back goes back we'll do that next
the harnesses went one on the seat belt center and one on the seat belt side
And now install the seat back in
and there you go!
and there you go!
Possibly a stupid question, but would this kit fit in the EP3? I know a lot of parts are interchangeable but I never figured out if the roll bars/cages would fit.
NewBorn_EG
Sep 19, 2004 04:18 PM
