Fried battery cable...Please help :(
Old Mar 30, 2011 | 12:45 PM
casperlt1's Avatar
Icon2 Fried battery cable...Please help :(
I'll start with saying I know I shouldn't have attempted this but I was stupid and did..was trying to clean the wiring harness up and extend a few to do a partial tuck.Well...I thought I had everything back together right,guess not.So I clicked the key on..dash lights came on and everything,then attempted to turn the car over and nothing,tried once more,nothing..all of a sudden,smoke started rolling out near the pass. side kick panel,then towards the back (battery relocated to back)alot of smoke.After freaking the fk out,and the smoke settled,I noticed the hot wire on the battery was fried from the battery to the firewall.I've checked the grounds but possible I missed something.What the hell did I do?Where should I start?Please refrain from telling me how stupid I am,cause I know...it won't happen again.Any help is greatly appreciated,I realllllly need to get this fixed.
Old Mar 30, 2011 | 12:47 PM
Dontoh's Avatar
Default Re: Fried battery cable...Please help :(
there's probably some burnt material around where the problem would be. thatd be my guess anyway
Old Mar 30, 2011 | 12:49 PM
casperlt1's Avatar
The only thing I see thats burnt is the battery wire I described.I'll keep checking to see if I can see anything else,but quick question,where is the ground that goes on the tranny?
Old Mar 30, 2011 | 02:26 PM
alphalanos's Avatar
hot wires, too much resistance. Check all you connections. How big of wire did you use.
Old Mar 30, 2011 | 04:16 PM
jam3z's Avatar
next time make sure you put a fuse for the hot wire within 1 foot of the battery.
did you put a grommet or protect the wire where it goes through the firewall? if not thats probably where your wire shorted out you are lucky your car didn't catch fire.
Old Mar 30, 2011 | 04:37 PM
vansxskater's Avatar
You either used a incorrect wire that could not hold the amperage or you had a short to ground which usually equals a carbaque.
Old Mar 30, 2011 | 06:55 PM
casperlt1's Avatar
The battery wire was enough before I did the wiring,there is a grommet at the firewall,I'll have to check more tomorrow
AccordJDM413
Jun 25, 2019 07:11 PM
hondamyheart
May 15, 2017 10:37 AM
b20hondacivic
Feb 5, 2013 07:50 PM
sleepin91teg
May 29, 2004 11:53 AM
crawdad689
Nov 21, 2003 11:35 PM
