Front wheel noise?
Old Mar 30, 2011 | 10:16 AM
michael-crxsi's Avatar
Default Front wheel noise?
I have a noise coming from the front passenger side noise. It is a clunky noise almost like a click. It happens when I go over very small bumps or turn slightly left. The cv boot is fine and I just had the driver side cv axel replaced. I'm not sure if it would be the wheel bearing or the axel? I have Koni yellows with h&r springs if that helps.
Old Mar 30, 2011 | 11:46 AM
NEIGHT 14's Avatar
Default Re: Front wheel noise?
Same happens to me, only when I press the gas on a turn it does it. I wonder whats up with it, can someone help us? Oh yeah also the more I turn the louder it gets
Old Mar 30, 2011 | 12:07 PM
90_EX_Civic's Avatar
might be your lower ball joint, or, do you have a funny feeling coming through your steering wheel? if it is might be your rack bushing, the one inside the rack.
Old Mar 30, 2011 | 12:08 PM
is your problem might be your axle. is it a clunky/clicking sound or a thudding sound?
Old Mar 30, 2011 | 04:23 PM
B16-CRX's Avatar
Could be wheel bearing/ upper or lower balljoints/ tie rod end or maybe something else is loose? make sure the springs are seated right and the struts are bolted in tight
Old Mar 30, 2011 | 04:36 PM
NEIGHT 14's Avatar
It's a clunky/ clicking sound
jayare05
Nov 25, 2012 08:21 AM
1_slow_crx
Sep 1, 2006 09:46 AM
sf89lx
Aug 26, 2004 10:05 AM
Carbcivic
May 28, 2004 02:13 PM
juicedricer
Mar 6, 2003 05:39 PM
