FS Honda B Series Turbo Kit, 3" Exhaust, Koni/GC, EG, DC, EF
Old Mar 30, 2011 | 07:16 AM
Origin's Avatar
Default FS Honda B Series Turbo Kit, 3" Exhaust, Koni/GC, EG, DC, EF
contact: swiftdelay@hotmail.com
currently not parting out turbo kit, but will entertain offers.
Turbo kit (turbo, mani, dp all hand polished): $2500
One-Fab topmount manifold (T3, Tapped for EGT sensor, but can be capped) for bseries
One-Fab 3" downpipe (2 O2 bungs)
One-Fab Dumptube
Precision SC34 Turbo .57 trim, .63 AR, 5 bolt housing, externally gated
Tial 38mm Wastegate (brand new still in box, polished)
Precision medium sized intercooler
Intercooler Piping
Greddy Type S BOV
3 Ply Silicone Couplers (Black)
T Bolt Clamps
All Hardware for turbo to mani, DP to turbo, etc
Oil Feed and Return (all stainless lines)
Tapped Oil Pan
Golden Eagle Sandwich adapter
Fuel Setup: $800 (will sell without wideband)
Hondata S300 with Mac Solenoid for boost by gear (SOLD)
Walboro 255 HP
All Stainless Fuel Lines with AN Fittings (includes line from filter to rail, rail to fpr, and from fpr to return)
BDL PolishedFuel Rail
Precision 880cc injectors (resistor box included)
Aeromotive FPR w/ Marshall Fuel Gauge
PLX M300 Wideband O2
Exhaust: $450
Kteller 3" Stainless Steel Mandrel Bent Exhaust with a Vibrant polished, offset tip muffler.
450f/550r. suspension has less than 1000 miles on it. for eg/dc. includes all 4 gc extended top hats and bumpstops. asking $850.
Muckman Stainless Steel braided line for wastegate - $25
Cometic Head Gasket for B18B. 81mm .075". Received the wrong gasket, was unable to return. Good for guys with high compression motors who want to go forced induction.
Cometic Head Gasket: $70 obo
Ebay clear corners for 92-95 Civic Insides of corners still need to be cleaned.
Corners: $20 (will not separate)
Two LS Motors with spun rod bearings. Only good for rebuild. Both of them came from a car I purchased, but now I need room so these must go.
1. B18B – 250 obo (still need to take apart to see damage)
2. B18A – 150 obo (bearing spun on #3, mains still in good condition, crank may be salvagable, but more than likely easier to replace.) can pm pictures of damage. will throw in a pre-obd distributor for $50
Pre-OBD PR4 ECU: $50
1. DA Front Spindles (Calipers/Rotors included) – SOLD
2. DA Upper Control Arms - $5 each
3. DA Front OEM Struts/Springs - $5 each
4. 2 Power Steering Pumps (pulley uses 1 row belt) - $5 each
5. DA Manual Pedals - $5
6. DA Master Cylinder/Booster – $10
7. DA Front Lower Control Arms - SOLD
8. Radiator Hoses - $5 for all
9. DA Flywheel - $10
10. Pressure Plate/Clutch (used/pressure plate has surface rust) - $5 each
11. Da Upper exhaust manifold w/ O2 sensor - $5
12. Starters (need rebuild) - $5
PreOBD Da Engine Harness - $50
PreOBD DA Chassis Harness (missing a few connectors that go into engine bay) - $50 ($25 if purchasing the engine harness)
1. CRX Radiator - $5
2. AC System for CRX (not sure if all lines are there, but have a few) compressor/mount/harness/fan/all seen included - $40
3. Fluid Reservoir for CRX - $5
4. 3 of 4 Mud Gaurds for CRX (front passenger has crack) - SOLD
5. Exhaust hanger for CRX - $5
6. Lower Exhaust Manifold/Cat/Heatshield for CRX HF - $5
1. CRX Battery Tray - $5
2. CRX HF Shift Linkage - $5
3. CRX HF Spindles - $10 each (comes with new brakepads in box)
4. CRX HF Axles - $5 each
5. Battery/Starter Engine Cable - $5
6. Underdash Gauge Cluster Harness - $5
1. CRX Passenger Headlight w/ driver side bracket - $5
2. CRX Center Tail Light - $20
3. CRX Glove Compartment - $5
4. Radiator Stays and a Clutch Cable Bracket - $5 each
5. CRX Rear Trunk Compartment Light - $5
6. CRX Rear Speaker Mounts – $5
7. CRX Center Console - $5
8. CRX Panels - $5
9. CRX Panels - $5
10. CRX Panels - $5
11. CRX Panels - $5
12. CRX (DX? 88-89) Gauge Cluster - $20
13. DA Gauge Cluster - $20
1. $5
2. $5
3. CRX Coin Pocket - $5
4. B Series AC Compressor (unsure of condition) came off an old LS motor - $10
5. DA Mirrors - $5 each
6. DA Rear View Mirror - $5
1. CRX Clutch Cable - $5
2. CRX Throttle Body Cable - $5
3. DA Throttle Body Cable (missing one tab to hold to firewall) - $5
1. Power Steering Pump Mount - $5
2. AC Mount - $15
3. AC Mount - $15
4. Transmission Torque Mount - $15
5. Transmission Torque Mount - $15
6. D Series Rear Engine Mount - $5
7. $5
8. $5
9. $5
10. $5
11. $5
98 Civic Driverside Airbag - $15
2 12" 1200 Watt Sony Xplods w/ box – $75 obo
Integra rear bumper, passenger door, driver fender
Would like to sell all as a whole. 100 obo
Parts SOLD:
DA Front Lower Control Arms – SOLD
Blue CRX Cargo Cover (2 pieces) - SOLD
CRX Tire Cover - SOLD
WW Side Skirts - SOLD
S300 - SOLD
Eagle rods - SOLD
90 degree wastegate arm - SOLD
Old Mar 31, 2011 | 06:38 AM
Origin's Avatar
Default Re: FS Honda B Series Turbo Kit, 3" Exhaust, Koni/GC, EG, DC, EF
all pm's replied.
Old Mar 31, 2011 | 05:50 PM
Origin's Avatar
spring rates added. gsr rods and s300 sold
Old Mar 31, 2011 | 07:48 PM
kuhwahh's Avatar
If you do part out please pm me! Bump!
kuhwahh's Avatar
part out Turbo kit*
Old Mar 31, 2011 | 07:49 PM
Origin's Avatar
pm'd
Old Apr 1, 2011 | 07:39 AM
Origin's Avatar
bump
Old Apr 7, 2011 | 07:31 AM
Origin's Avatar
bump
Old Apr 7, 2011 | 12:47 PM
fakieSI's Avatar
if you decide to part out kit pm me how much for the turbine and some closer pics of it... thanks brah
Old Apr 8, 2011 | 06:22 AM
Origin's Avatar
ill let you know as soon as i do. thanks.
Old Apr 9, 2011 | 09:18 PM
spank88's Avatar
is that exhaust for a crx and any pic
Old Apr 10, 2011 | 07:21 AM
dc2_88's Avatar
Emailed you on the suspension. Very interested And ready to buy it today or asap. Thank you
Old Apr 11, 2011 | 07:05 AM
Origin's Avatar
sorry the exhaust is for an eg, and no pics currently, still on car but will be removing soon so i will get pics then.
responded to your email. appreciate it.
Old Apr 13, 2011 | 03:13 PM
Origin's Avatar
bump
Old Apr 17, 2011 | 07:55 PM
mmcd's Avatar
if u part ill take the turbo
Old Apr 20, 2011 | 01:44 AM
eddieisazombie's Avatar
wish i still had my crx i would get some of those parts just to have on stand by
Old Apr 20, 2011 | 06:30 AM
Origin's Avatar
thanks for the bumps. ill make sure to update the thread when and if i do decide to part.
90 degree bend sold.
Old Apr 20, 2011 | 02:18 PM
Yang907's Avatar
bump...got any pic of aermotive fpr
Old Apr 21, 2011 | 06:49 AM
Origin's Avatar
pm'd
Old Apr 24, 2011 | 10:59 AM
Worldsport's Avatar
PM'd about Koni/GC's
Old Apr 24, 2011 | 06:43 PM
cdaiscool's Avatar
If/when you part it out, I'm interested in the Golden Eagle sandwich plate. LMK if you're interested in selling that to me.
Old Apr 25, 2011 | 07:01 AM
Origin's Avatar
thanks, will let you know when i decide to part.
all pm's replied
Origin
Jun 3, 2013 10:27 PM
Origin
Southeast (Sales)
Apr 4, 2013 07:03 PM
Origin
Jul 10, 2011 01:59 AM
Origin
Apr 21, 2011 06:47 AM
IN VTEC
Mar 28, 2008 12:33 PM
