Windsheild washer problem
When I bought the car the windsheild washer motor didn't work at all. So I looked in the tank. It was empty, so I filled it up and all the fluid just ran out the bottom where the plastic tube connects to the tank. Tightened the tube to the tank filled it up with fluid. The motor works but still no fluid comes out. I've even tried taking a small syringe and backflushing the nozzels. Still nothing. Any ideas on how I can make this work. Thanks in advance for your help.
Have you tried disconnecting the hoses at the nozzle to make sure it is getting that far? I still have trouble with mine, now I don't even get the pump motor sound.
I have the same problem, and I think it's a leak in the line somewhere. Out of the 4 jets, the one on the far left works fine, the next one has almost no pressure, and the two on the right get no pressure at all. Take a look at the lines while someone is pressing the button.
get some aquarium air-hose and just re-do the whole thing for a couple bucks because the original hoses are ugly by now
I had some already at the house--it works
BlackYoshi
Oct 17, 2005 08:23 PM
