FL 95 GS-R .g511m. ob1. clean. tastefully modded.
THEFT RECOVERY TITLE
NO ACCIDENTS
Year: 1995
Make: Acura
Model: Acura Integra GS-R
Chasis: 170,xxx miles
Motor: 9,XXX miles
Color: Galapagos Green g511m
* ALWAYS garage parked, washed weekly, waxed monthly.
* METICULOUSLY maintained
* Very tastefully modded
* NO POWER STEERING
Exterior:
*94-97 Front
*94-97 Tails
*SI-VTEC Front Lip
*SI-VTEC Corner Signals
*OEM Mudguards Front/Rear
*Rear Wiper Delete
Interior:
*GS-R Black Cloth Front/Back Seats
*00' GS-R Steering Wheel
*OEM Cargo Tray Cover
*Spoon Sports Shiftknob
*Broadway Mirror (300mm)
*OEM Acura Integra Type R Floormats
*GSR Cluster
*JDM ITR Clock
*JDM ITR Climate Control
*JDM ITR Window Switches
*JDM ITR Cig Lighter/Ash Tray
*JDM ITR Cup HOlder
*OEM Power Window & Locks
*Pioneer Headunit
*Pioneer Speakers
Motor: B18C1 9,xxx on motor, will continue as I drive this daily.
*Motor/tranny fluid changed ever ~3k miles.
*All New OEM Seals, Fittings
*OEM Timing Belt
*OEM Headgasket
*NEW ARP Rod Bolts
*NEW OEM Rings
*NEW OEM Bearings
*NEW OEM ITR Oil Pump
*NEW OEM ITR Water Pump
*NGK Plugs + Wires
*Hasport U70A Solid Motor Mounts
*RMF Replica Headers
*Skunk2 Pro Intake Manifold
*AEM Fuel Rail
*AEM FPR
*B&M Gauge
*330cc Injectors
*Fluidyne FULL SIZE Radiator
*OEM Honda Fluids
*2x Slim Fans
*MINT B18C1 Tranny
*fluids changed every 3k~ miles with OEM + GM Syncromesh.
*Fidanza 7.5lb Flywheel
*ACT Twin Diaphragm Pressure Plate
*4 Puck Unsprung Competetion Clutch
Exhaust:
2.50 piping CAT BACK matted to Spoon Sports N1 Muffler.
Suspension:
*PIC Apex 10kF/8kR
*PIC Bushings ALL AROUND
*17x9 5ZIGEN FN01CR wrapped in BRAND NEW Falken 912's
*GS-R 24MM Front Sway Bar
*GS-R 14MM Rear Sway Bar
*BLOX Front/Rear Camber Kits
*Cross drilled/slotted Rotors
*Hawk HPS pads
ECU:
GS-R P72 OBD1 ECU Tuned on eCtune with a base map.
*2 Step Launch Control
*8.5 Rev Limit
*CEL Shift Light
Security:
*Viper 5901 Stealth Install by Mike @ BBY
*Proximity Sensors, Hood Sensor, Shatter Sensor.
*Kill switches etc.
PARTING OUT AS OF 5/13/11
Contact information;
I'm never on here, text is best.
More pics upon request
No negativity, thanks.
954-818-0181
Don't waste my time if you dont have the money.
Thank you
NO ACCIDENTS
Year: 1995
Make: Acura
Motor: 9,XXX miles
* NO POWER STEERING
Exterior:
*94-97 Front
*94-97 Tails
*SI-VTEC Front Lip
*Rear Wiper Delete
Interior:
*GSR Cluster
*JDM ITR Clock
*JDM ITR Cup HOlder
*Pioneer Headunit
*Pioneer Speakers
*OEM Timing Belt
*OEM Headgasket
*NEW ARP Rod Bolts
*NEW OEM Rings
*NEW OEM Bearings
*NGK Plugs + Wires
*AEM Fuel Rail
*AEM FPR
*B&M Gauge
*330cc Injectors
*OEM Honda Fluids
*2x Slim Fans
*MINT B18C1 Tranny
Exhaust:
Suspension:
*PIC Apex 10kF/8kR
*Hawk HPS pads
ECU:
*8.5 Rev Limit
*CEL Shift Light
Security:
*Kill switches etc.
954-818-0181
Thank you
bump
