95 Accord Lighting ISSUE HELP!
hey, ok its going to get a little confusing. but i bought my 95 accord and the high beam lights would not work at all even tho i changed the bulbs, i didnt really care. but i just bought 1 peice halo lights for it and i pluged the halo/marker lights in an it worked fine, so i shut the lights off and pulled the assembly out to put the hid's in and finish the wiring, i then went back pluged it in and nothing, no marker lights, no tail lights, no dash lights, no licence plate lights. But signals work, brake lights work, head lights work and when the e brake is off the front running lights work but not the rear. so i did some research, and found the DRL relay box under the dash, and yes i found some bad soldering connections and re soldered them. well now my high beams work lol but still nothing else. i still keep on doing research but im out of ideas, fuses are good, my only idea is replaceing the DRL relay box even tho the solder is good the relay could be pooched. if anyone else knows what to do and or has better ideas let me know!! my fiancee is due anytime to give birth and i need lights if im going to be waking up in the middle of the night rushing her to the hospital! lol id like to have it fixed by tommorow! please help!!!!!
same symptoms for my 96 accord for the most part. Its been down for a couple of days. and all i can find is a couple people saying to check the dimmer switch for a bad ground or worn connection. I'm going to replace it tomorrow. if it works i'll hit you up on here and tell you. And if there is any chance you could let me know if you come across a solution that would be awesome. I'm really hoping its the dimmer switch. 5 bucks or free if it fits in you jacket at pick a part
dragracer7383
Feb 4, 2019 03:36 PM
olskool
Dec 23, 2009 07:40 PM
