F23 to H22 swap
Old Mar 29, 2011 | 05:25 PM
H22CL/lowandslo's Avatar
Icon3 F23 to H22 swap
i just did this swap not a few weeks ago in my 99 Acura CL...very technical to say the least but fun...i did alot of research on here to figure out what i needed to be ready for and found out alot of nothing to be honest....
here r a few need to know details if anyone needs them, and feel free to ask questions if i dont include something you need.
as far as motor mounts go only one needs to be modified is the driverside mount. you have to use the h22 mount and it is too wide to fit so the mounting bracket needs to be stretched or the mount itself needs to be ground down a slight bit.other than that it will drop right in..the h22 sits back alot further so it is really close to the fire wall so make sure your coolant lines and what not r in place before completely putting the motor in.
i used the F23 tranny because the H22 came from an automatic car...the tranny bolts right up..used the f23 flywheel and a F23 clutch...but the H22 clutch will work as long as u have the right alignment tool.
the wiring needs a little fixing...nothing major just a few plugs needs to be lengthened...the dizzy plug is one of them...the IAC is another...the F23 IAC is a 3 wire plug, but the H22 is a 2 wire plug. All you have to do there is ground the black (ground) and attach the other two wires from the 2 wire H22 plug. i think there was one or two more not sure but you will see when doing the swap.
not here is the fun part.. THE DIZZY...you will notice that you F23 dizzy is an internal coil, and the H22 is an external coil...well he is what you do...you will have to modify the dizzy for it to fit an internal coil in it not a big deal just about 20 minutes with a dremil tool....i know this sounds crazy but saves alot of heart ache...use the factory F23 dizzy wiring inside the H22 dizzy, and as far as the cap and the coil go..use the cap and coil from a 1991 CRX SI.. yea it sounds dumb but it works promise. so in the end it will be a H22 dizzy, shaft, and button, F23 wiring, and 1991 CRX SI cap and coil.
also you will have to swap throttle cables...the factory cable is too long....
only thing my car does not have is cruise control...still has AC and PS.
let me know if any of this was help full
Old Mar 31, 2011 | 12:34 PM
benoit's Avatar
Default Re: F23 to H22 swap
i have an f23b in my 98 honda accord sedan. im wondering if you know if the a h22a would bolt in the same way it would in your cl
Old Mar 31, 2011 | 05:23 PM
accords and CLs are exactly the same car just look different. as far as i know
Old Mar 31, 2011 | 06:02 PM
benoit's Avatar
im just wondering what you mean by dizzy?
Old Mar 31, 2011 | 11:41 PM
MAD_MIKE's Avatar
MM Gruppe B
Distributor
Old Apr 1, 2011 | 11:50 AM
benoit's Avatar
thank you
Old May 12, 2011 | 08:20 AM
Mass_Motors's Avatar
Thanks for the info. I am doing a h22 swap from my 97 Prelude to my 99 CL. Did you run into issues with the ECU, are you using a CL or Prelude ECU?
Old May 12, 2011 | 12:23 PM
Bwill9886's Avatar
Unless you swapped that F23b in there I believe you mean F23a1 or F23a5 (depending on trim level).
And yes it will be basically the same.
OP, have you driven it much since the swap completion? I'm just curious how the H22a operates with the longer gears and haven't heard much real-world experience.
Old May 15, 2011 | 10:46 AM
i am still running the F23 ECU and it runs it fine only big issue is the rev limiter is still at 6300 instead of the 7500 the H22 can rev to, and it is dumping just a little to much fuel.
I drive the car everyday... it is my DD...the f23 trans to me is an amazing setup with the H22....especially on long trips cruisin at 75 or 80 in 5th gear just barely under 3000 rpms.
Old May 15, 2011 | 02:57 PM
benoit's Avatar
im doing this swap and its a pain in the *** for me right now. did you have to get a new intake and header downpipe? and also is yours a jdm h22a or usdm h22a
Old May 27, 2011 | 06:00 PM
east_925_bay's Avatar
im tryin to rip out my f23a1 outa my 99 accord lx coupe bcuz it haz no power to it at all i think an im wantin to dropa new engine pero idk wuz the bez route to go engine wise for the most power... iza h22 perfect for it o should i pik sumthin else bcuz im really confused an itz drivin me crazy
Old May 28, 2011 | 01:12 PM
benoit's Avatar
youll need a new ecu header down pipe intake change yor driverside mount and maybe a bit of changes to your distributor. its defenitely a decently hard swap i believe
Old Jul 17, 2012 | 12:07 PM
walter1187's Avatar
Originally Posted by MAD_MIKE
Distributor
hello everyone . I have a 2000 honda accord with h22a4 swap. just got it done
couple days ago but emission won't pass till i fix my iacv .
the accord ex has a 3wire plug connector (yellow and black/blue & black/black) this are the 3 wire colors for the iacv plug, But the h22 iacv only has two wire plug connector. so i don't know what do i need to make this work.
does anyone knw the diagram (WIRING AND ECU) for this please???
i really need to get this fixed cus my car runs like crap.
thanks
FOLLOW THE PICs
http://imageshack.us/photo/my-images...061800811.jpg/
http://imageshack.us/photo/my-images...061800812.jpg/
Old Jul 17, 2012 | 12:09 PM
walter1187's Avatar
Distributor
thanks
FOLLOW THE PICs
jdm 1080p
Oct 8, 2012 03:27 PM
nus_dogg
May 30, 2009 07:40 AM
h22coupeSTB
Nov 7, 2008 06:20 AM
Sonnick
Feb 5, 2007 07:12 AM
eghondafamily
Jan 15, 2007 07:27 PM
