Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Ody 2005 Wheel Alignment
Old Mar 29, 2011 | 01:57 PM
nirvana_1959's Avatar
Default Ody 2005 Wheel Alignment
Help me to figure out what this report says please:
http://www.kavimconsulting.com/index...lAlignment.JPG
Not sue why the dealer didn't make effort to change the red numbers.
Thanks.
Old Mar 30, 2011 | 05:38 AM
Default Re: Ody 2005 Wheel Alignment
Has the dealer done ok job ?
Old Mar 31, 2011 | 10:52 AM
OK! Last try :-(. Anyone out there that can make something out of the readings ?
Old Mar 31, 2011 | 03:15 PM
K&NGEO's Avatar
I just had my 05 Ody aligned a few days ago. My toe setting was way off, camber setting is very similar to yours. The tech told me the camber setting can not be adjusted on the Ody. I think your tech did good to align it. your camber may be off due to worn bushings or b/j's, but since its very slight I woulnt worry about it.
Old Apr 1, 2011 | 10:32 PM
90sedan's Avatar
Only toe is fully adjustable on your vehicle, and only are slight camber adjustments possible on the front of your vehicle. Looking at the sheet, none of the toe adjustable angles are more than .001 out, which is nearly perfect. Toe is the only alignment angle that affects tire wear, so there isn't any worries there.
For the camber that's still out of spec after the alignment, it's not anything you can correct without replacing suspension components. And since it won't have any adverse effect on tire wear or handling it's not something you should worry about or spend the money to correct. Note that cross camber over .5 degree can cause a pull, but no real concerns other than that.
The tech did a good job.
ZCHondaCRX91
Suspension & Brakes
Nov 3, 2011 03:49 PM
balili89
Feb 20, 2008 05:57 AM
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
jdmstreethatch
Suspension & Brakes
Feb 4, 2006 11:52 AM
TypeR II
Suspension & Brakes
Jun 3, 2005 02:21 PM
