Synergy Turbo Group buy
Synergy Turbo is offers a group buy for you turbo needs. We are offering a group buy on our universal turbo.
This group buy will be open for 1 month only. Start Date 3/29/2011 End date 4/29/2011
http://www.synergyturbo.com/?page_id=71
Universal .57 AR
Car Model Turbo Model Part Number
Universal .57 AR TD06H-20G-8 (11B) ST06H20G8UN57
Max HP Flange
430 T25/28
Compressor Diameter CFM
52.5/68mm 640
lbs/min Turbine AR
46 57
Nozzle Area Wheel Diameter
8cm 58.8/67.14mm
Wastegate Bearing
External Journal
Cooling MSRP
Oil and water $1,058.20
Universal .73 AR
Universal .73 AR TD06H-20G-10 (11B) ST06H20G8UN73
Max HP Flange
440 V Clamp
52.5/68mm 640
lbs/min Turbine AR
46 73
10cm 58.8/67.14mm
Wastegate Bearing
External Journal
Cooling MSRP
Oil and water $1,276.00
Please PM BasisSport
for special pricing.
Authorized Synergy Turbo Dealer
Ryan "RT" Tsuboi
Basis Sport Tuning
151 S. Wineville Ave., Unit K
Ontario, CA 91761
PH: 909-740-6492
AIM: rt@basissporttuning.com
Universal .57 AR
Max HP Flange
430 T25/28
52.5/68mm 640
lbs/min Turbine AR
46 57
8cm 58.8/67.14mm
Wastegate Bearing
External Journal
Cooling MSRP
Universal .73 AR
Max HP Flange
440 V Clamp
52.5/68mm 640
lbs/min Turbine AR
46 73
10cm 58.8/67.14mm
Wastegate Bearing
External Journal
Cooling MSRP
Ryan "RT" Tsuboi
Basis Sport Tuning
Ontario, CA 91761
PH: 909-740-6492
