95 civic idle prob
Old Mar 28, 2011 | 11:03 PM
richi86's Avatar
Default 95 civic idle prob
my car idles up and down from 1100 to 1500 rlly fast what could be the cause ? i changed the tps that didnt help and idk if its the iac or not but when that is plugged in if i hit the gas it stays at 2500 ? so i unplugged it could the iac cause this ?
http://www.youtube.com/watch?v=ff94UkVeNEQ
Old Mar 29, 2011 | 03:59 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 95 civic idle prob
Clean the IACV/FITV.
Old Mar 29, 2011 | 04:33 AM
jmurphy's Avatar
also there is an area on your throttle body by the Idle Control Sensor you can adjust your idle with a screw driver
Old Mar 29, 2011 | 06:14 AM
Former User's Avatar
If you use your finger to cover the port leading to the FITV inside the throttle body, does the idle speed become normal?
Old Mar 29, 2011 | 04:31 PM
richi86's Avatar
Post Re: 95 civic idle prob
i used a screw driver to adjust the idle and that didn't help but i took the throttle body off and the FITV rattles if i move it around i think a piece in it is broke so im going to get a new throttle body tomorrow and try that and see what happens
Crxdriver1989
Dec 19, 2017 01:28 AM
black bandit
Jan 14, 2008 04:26 AM
924doorEG
Nov 19, 2007 08:15 AM
k_lude
Oct 2, 2006 07:25 PM
ATS*Mark
12
Dec 22, 2005 07:14 PM
