b17a1 vss and jdm b16a vss
Old Mar 28, 2011 | 10:49 PM
shininja11's Avatar
Default b17a1 vss and jdm b16a vss
im swapping out my beat up b17a1 ys1 tranny for a jdm b16 lsd tranny and everything is going pretty good except for the vehicle speed sensors arent the same!!!!
my b17a1 vss is cable and the jdm vss is electrical. I tried swapping the speed sensors but it wouldnt fit. Am i just **** out of luck? I would like to know if there is something anything i can do to make this swap work.
Old Mar 31, 2011 | 08:11 PM
Mindgamez's Avatar
Default Re: b17a1 vss and jdm b16a vss
They should just change out just fine. The Gears and lengths are exactly the same. Try turning the trans when u try and fit it in maybee the treeth were not lined up and stopping it from going all the way down.
http://www.vtecminis.com/archive/index.php/t-228.html
That might help
Old Mar 31, 2011 | 10:03 PM
92db2gs-r's Avatar
if you wanna donate a b17 tranny let me know lol.
Old Apr 1, 2011 | 04:29 PM
DA9Sleeper's Avatar
i love DB2
Old Apr 2, 2011 | 03:28 AM
shininja11's Avatar
That might help
thanks for the reply! but the gears and lengths on the vss are not the same. i forgot to mention the jdm tranny has lsd and its going into my 92 gsr. i read your link and thank you for that btw. but Im just gonna use the jdm b16a vss, remove the electrical part and stuff my cable in there. i'll let you know how it goes.
Old Apr 2, 2011 | 11:32 AM
94EG8's Avatar
Seagull Management
'90 - '91 B18A VSS *may* work.
Old Apr 2, 2011 | 04:03 PM
shininja11's Avatar
thank you! yeah i'll check that out. i'll drop by the junk yard and see if they have any. thanks again
EF_ST@TUS
Jan 30, 2008 09:12 PM
alscrx
Jun 14, 2007 08:50 PM
Firestarter
Sep 11, 2005 12:28 PM
PhatHardy
Jan 31, 2003 04:55 AM
charjacq
Nov 8, 2002 05:12 AM
