integra wheel knuckles fit on a crx?
Old Mar 28, 2011 | 07:11 PM
e1ght4vii's Avatar
Default integra wheel knuckles fit on a crx?
i read in a magazine that the front knuckle assembly from a integra fits on a crx and that they are bigger calibers and obviously bigger wheels is this true? if so which integra does it need to be? theres a event at the local junk yard going on this summer that if u pay admission if u can carry it u can take it so im thinkin of pullin these parts off a integra for my rex
Old Mar 28, 2011 | 07:14 PM
Fo-Do Fanatic's Avatar
Default Re: integra wheel knuckles fit on a crx?
Any 90-93 Integra front knucles fit. If you use those, I HIGHLY suggest you get the NON ABS brake booster and 15/16th's brake master to go with it. The stock 13/16th's booster isn't going to offer enough pressure to help you stock good.
Though they fit, mind you, they ARE taller and will add a little bit of negative camber. Not much maybe .5-.7 degree's more. You will need an alignment after installing the knuckles too.
Old Mar 28, 2011 | 07:50 PM
e1ght4vii's Avatar
so assuming the integra is still there during the event if i take the front knuckles off i should take the master and the booster if it doesnt have ABS?
Old Mar 28, 2011 | 08:24 PM
Yes. Make 100% sure it does NOT have ABS. The brake master and booster will NOT fit. You should probably get the prop valve and the trailing arms as well.
1984eghatch
Jan 14, 2015 06:06 AM
vtec8200
Apr 6, 2009 12:49 PM
88EFhatch
Jul 12, 2005 08:28 PM
jlsmi2
Feb 3, 2005 06:40 PM
streetrage
23
May 30, 2004 09:40 PM
