GV1390s full part out. Almost everything brand new 0 miles!
Well I decided I want to move onto the rwd world and finishing my car wasn't worth it, so I'm parting it out. I'd like to sell the rolling shell (95 Integra DC2 JDM Front)and as much of it that I can at once so its easier. The shell as you can tell from my build thread is clean. No rust whats so ever, I recently degreased every square inch of underneath the car. I also put everything brand new with 0 miles on it: all 4 corners wheel bearings, inner and outer tie rod ends, lower and upper ball joints, powersteering rack, arp extended wheel studs, energy rear trailing arm bushings I put in over summer,new mud flaps, etc etc. The interior is mint. It has the real jdm black housing head lights with fogs up front, I sent out the front and rear bumpers to get painted last week I can cancel this If I have too depending on the deal I could work out with the buyer. The front had your typical thruway road chips and the rear someone bumped into me and some paint flaked off. PM a reasonable offer on this.
Anything that doesn't have a price PM me a offer.
-B18c GSR block needs a hone its been sitting in the trunk of my winter car walls on it are find though. Also have the gsr crank and rods to go with this. SOLD
-GSR head just got cleaned and assembled with brand new viton valve stem seals, skunk2 pro series dual valve springs and skunk2 pro series titanium retainers. Has 0 miles on it. SPRINGS AND RETAINERS SOLD. Still have the gsr head with new valve stem seals. EVERYTHING SOLD
-Built b16 trans. Phantom Grip and all new bearings with carbon coated synchros. Not many miles on this whats so ever, no grinds or pop outs. $1200 SOLD
-Skunk2 stage 1 pro series cams BNIB $460 SOLD
-New head gasket .30 B series $75 SOLD
-ITR dual valve springs $80
-BNIB ACL race bearings full set $80 SOLD
-TRI Y rep header with extension BNIB $350
-Omni 70mm TB brand new $100 SOLD
-Skunk2 pro series intake manifold with spacer $220
-ITR front sway bar $80
-Omni rear polished Lcas BNIB $180
-Brand new ITR front 11.1" Calipers,brakets and pads.
-Competition stage 5 4 puck sprung clutch Just installed this summer
-Excedy (gotta double check on the brand) Light weight flywheel
-Dual core radiator
-USDM ITR cluster with 0 miles on it
-Chase Bay grounding kit $40 SOLD
-Chase Bay clutch line kit $70 SOLD
-1/2" 30ft of Braided wrap around wire sleeving ( this is the loom that is split all the way down the center so its easy to wrap wires)
$50
-GSR AEM cold air intake $20 SOLD
-GSR ARP head studs $80 SOLD
-949 6UL miata racing wheels. 4x100 15x8 12 lbs a piece 2 rears are brand new potenzas or direzzas cant remember and the two fronts are toyos one is pretty good and the other is decent. SOLD
-3" Kteller catback with apexi ws2 muffler.
-B18 hasport mounts.
Also have b18 alternator, starter, spare axles, fuel rail and that bs.
Heres some pics
http://s1023.photobucket.com/albums/af352/italiano1390/
Im sure Im forgetting a ton of ****. I mainly want to sell the shell and as many parts as I can with it as a package deal. Trying to move this stuff quick. PM if you have any other questions thanks!
-Dual core radiator
$50
Heres some pics
Wow no **** I guess you dont need that cable it was cut anyways. Are the headstuds new? And was that head gasket larger diameter or stock?
