lsv crx.
i am new to the whole b series and civic scene, coming from a long line of accords and h22's. so i am looking for some advice on what all i need to put my lsvtec in my crx si.. i have so far mounts, shift linkage, cable to hydro tranny adapter, obd0-obd1 conversion,chipped p06, and axles. do i need b series spindles? and also will an aluminum half radiator be sufficient? thanks in advance!
* will post some more pics of my crx in progress when it stops raining, along with my motor.
i think as long as you have a dx or si your spindels will work dont forget you are going to need a ls block and vtec head didnt see that on your list...
...also if your car is not a si you will need to convert to mpfi
Read this:
http://www.b20vtec.com/forums/b-seri...tec-guide.html
Only thing I think isn't in that post is a GSR water pump. The LS pump is not geared to spin the RPMs a GSR can and only turns the water into foam. At least that's what I've read elsewhere.
MulletManRockStar
Nov 6, 2004 04:07 PM
