Suspension suggestions for eg8
Ok so I just ordered the following suspension components for the eg8:
H&R Sport lowering springs 1.75 Front 1.6 rear drop
Koni yellow sport shocks
Megan lower control arms
Eibach front and rear anti roll sway bar kit
Koni shock mount busings
The car is sitting on clean si wheels.... Does anyone think I'm missing any parts to make my suspension complete?
You already ordered, but your looking for suggestions? You did it backwards, but I'll still try and help you.
Loose the LCA's, not only do the bushings suck, they aren't requried. The only LCA's that are worth a damn are Function7, and OEM.
The springs and the shocks, are great choices. Easily the best OTS shock.
What does the Eibach sway bars come with? Endlinks? Bushings? Hardware?
You Should of Asked First then Buy........
Yea I Heard Megan are POS
Should of got K sport, or Blox LCAs
Should of probably got G/C coil overs IMO
and if you want a whole aftermarket suspension then buy rear adjustable camber kit. but you don't really need it.
Blox lca's are peices of **** too!!
I really cant speak to much on the total effect of strut bars, as I dont have any.
What I have seen is, 3 point strut bars and 4 point are the way to go.
Does the car currently have a front sway bar?
If not, you will need to get all the mounting hardware, and endlinks for them.
Tie rods, lower ball joints,upper control arms, as well as bushings would likely have a great effect on the car.
Update: I also picked up lower ball joints, inner and outer tie rod ends, and 2 sway bar links... I think the only thing I need to get now is upper control arms... Then I think my suspension should be completely redone... Any other things im missing?? LMK
energysuspensionparts.com
However, I reccomend you look into the PIC bushing kit. Instead of poly, it is hard rubber. You literaly throw it in, and forget about it. it does cost a bit more about $100, but replaces almost every bushing. The ES bushing kit doesn't.
But sence you already bought control arms it may be good for you. But do plan on replacing the rear LCA bushings.
You will need 4 endlinks. 2 front 2 rear.
RiskEverything
Jan 31, 2008 11:45 AM
199y, arm, bars, eg8, good, honda, race, rear, release, strut, supension, suspension, suspensions, suspention, upper
