Suspension & Brakes Theory, alignment, spring rates....
Looking for a firm ride without lowering
Old Mar 28, 2011 | 11:53 AM
katoeh2o's Avatar
Default Looking for a firm ride without lowering
my ride is a 2000 civic ex. Currently running bilstien shocks with eibach pro kit spring. It rides well but is to low for me.
I am open to suggestions on springs that will work with my bilstien shocks and maintain close to stock height. Right now I am leaning toward ground control coilovers or H&R oe sport springs. I would likely run the ground controls at or near there max height witch is supposd to be .5 inch lower than stock.
Old Mar 28, 2011 | 12:17 PM
racebum's Avatar
Default Re: Looking for a firm ride without lowering
the ground controls would depend on which length springs you buy. 8s front and back should allow the height you're after. if you want to keep the car firm but not hard somewhere around the 350/300 or 400/350lb rate sets would work for you. ordering GC's i found was easiest going direct. requesting the before mentioned is easy and it cuts out the middle man
Old Mar 28, 2011 | 01:56 PM
TunerN00b's Avatar
Before buying anything intended for adjustable height use, have you considered just adding rubbers to the stock springs to increase their rate?
Old Mar 28, 2011 | 02:12 PM
katoeh2o's Avatar
thanks for the suggestion on the ground controls. And as for the rubber inserts I think I require more proformance than those offer. Lol
Old Mar 28, 2011 | 05:20 PM
soloteg's Avatar
Hmm..interesting idea, it is up to a 50lbs spring rate addition.
http://www.longacreracing.com/articles/art.asp?ARTID=31
Old Mar 29, 2011 | 07:50 AM
zeroartgfx's Avatar
too low? never heard of it.
Old Mar 29, 2011 | 08:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
which is of no use whatsoever to the OP's questions.
07rebel
Honda Civic (2001 - 2005)
May 3, 2007 01:56 PM
vietnogi
Apr 5, 2005 02:54 PM
ZexyAccord
Mar 13, 2005 03:45 PM
SpecialEdScott
Mar 1, 2003 01:12 PM
arete213
Oct 3, 2001 03:39 AM
