01 civic LX wont shift from park... yes another one...
I've done quite a bit of searching and I'm still stumped...
2001 Civic LX Auto trans
Back story -
For starters, it's not my car, car came to me needing a head gasket replaced. It still ran, and I drove it onto my trailer to get it to my garage, no problems.
Replaced the head gasket, never touched the trans.
Started it up, went to go back it out of the garage, and the trans shifter wont let it move from park.
I have check the common things,
-Brake lights DO work
-All fuses seem good (Horn works)
-Checked fluid in trans, kinda dirty, but not low.
-If you put the key in the little hole, it will shift, so I dont think it's a problem with the shifter itself
Just has me stumped because I drove the car before I did anything, and it shifted out of park no problem... Pull the head and replace the gasket, now it wont shift...
So any ideas?
Thanks in advance
Back story -
So any ideas?
Thanks in advance
My suggestion would be to see if you can get it in to Neutral to start the car. To do so, follow these steps from the Owner's Manual:
Shift Lock Release
This allows you to move the shift lever out of Park if the normal method of pushing on the brake pedal and pressing the release button does not work.
1. Set the Parking brake.
2. Remove the key from the ignition switch.
3. Put a cloth on the edge of the Shift Lock Release slot cover next to the shift lever.
Use a small flat-tipped screwdriver or small metal plate neither are included in the tool kit) to remove the cover. Carefully pry off the edge of the cover. 4. Insert the key in the Shift Lock Release slot.
5. Push down on the key while you press the release button on the shift lever and move the shift lever out of Park to Neutral.
6. Remove the key from the Shift Lock Release slot, then reinstall the cover. Make sure the notch on the cover is on the left side. Depress the brake pedal and restart the engine.
The car starts, thats not the problem, and yes I know that I can do that to get it into gear, but my issue is that it wasn't doing this before I worked on it, and I don't want to give the car back to this guy with something else wrong...
Nope, no lights on in the dash. I hooked the computer up to it just to see if there were any codes stored in it, and nothing.
Symptom: Shift lever cannot be moved from Park while you're pressing the brake pedal.
Probably Cause: A problem with the shift lock system.
To troubleshoot it, do the following.
1. Disconnect the steering lock assembly 6-Pin connector.
2. Turn the ignition to ACC (I) or ON (II)
3. Connect the positive (+) battery terminal to terminal #4 of the lock assembly connector, and the negative (-) battery terminal to terminal #3.
Terminal side of the male terminals
4. Check the key interlock solenoid operation. You should hear a clicking sound while the ignition stays in the ACC (I) or ON (II) position, and you should not be able to turn it to the OFF (0) position.
Does the key interlock solenoid operate properly?
Yes - Go to step 5
No - Faulty key interlock solenoid/switch. Replace the ignition key cylinder/steering lock assembly.
5. Check for continuity between terminal #3 of the steering lock assembly connector and a body ground.
Wire side of female terminals
Is there continuity?
Yes - Go to step 6
No - Repair an open in the wire between the #3 terminal and ground (G401) or repair poor ground (G401)
6. Turn the ignition switch ON (II) and measure the voltage between terminals #3 and #4 of the steering lock assembly.
Is there battery voltage?
Yes - Go to step 7
No - Check for an open or short in the wire between the #4 terminal of the steering wheel lock assembly connector and the multiplex control unit. If the wire is okay, check for loose terminal fit in the multiplex control unit connectors. If necessary, swap the multiplex control unit with another one and recheck.
7. Disconnect the 4-Pin park pin switch connector. (It's under the gear position indicator, on the driver's side of the shifter, beneath the center console, and it has two wires coming out of it. One of which is the gear position indicator light)
8. Check for continuity between terminals #3 and #4 of the park pin switch connector while you move the shift lever in-and-out of the Park position.
Terminal side of male terminals
Is the no continuity with the shift lever in the Park position, and continuity with the shift lever in any position other than Park?
Yes - Repair open or short in the wires between the park pin switch connector and the multiplex control unit. If the wires are okay, check for loose terminal fit in the multiplex control unit connectors. If necessary, replace the multiplex control unit with another one and recheck.
No - Inspect the park pin linkage. If the linkage is okay, replace the park pin switch.
Yes - Go to step 5
Yes - Go to step 6
Yes - Go to step 7
Jakester9500
Jul 8, 2017 03:24 PM
