Water pip o-ring replacement
Old Mar 27, 2011 | 10:05 PM
GoSickemRobert's Avatar
Default Water pip o-ring replacement
I know there are probably threads about a replacement elsewhere, but I have a different question...
So i need to replace these since when I took the water pipe off, both of the o-rings stretched and developed tears. I was wondering if both sides are the same size, since napa has a "water pump to water pipe o-ring" but not the other. I told napa to send 2 of those hoping they are the same for both sides of the water pipe.
If it is correct that they are the same for both sides let me know and also how hard is it to pop back on into the hole? the o-rings should not fold out? Don't want to be making more problems for myself
Old Mar 27, 2011 | 11:48 PM
.Manny.'s Avatar
Touching My Member
Default Re: Water pip o-ring replacement
they are the same on both sides. get OEM o-rings. I usually lube them a bit to get them to pop in easily.
Old Mar 28, 2011 | 07:19 AM
ok thanks a lot for the quick response. i called honda when I woke up and got them holding 2 for me.
Ainsworth03
Honda Civic (2006 - 2015)
Jun 27, 2014 12:56 AM
JuneBugDrfter
Feb 5, 2013 08:57 PM
fast92hatch
Oct 27, 2007 07:12 PM
91AccordSE
Sep 8, 2004 05:44 PM
