eg9 getting painted..have questions plz chime in...
Old Mar 27, 2011 | 06:44 PM
low13da9's Avatar
Default eg9 getting painted..have questions plz chime in...
ok....where can i get milano red paint and how many gallons,and what else is needed ,,like base,clear,primer,sealer,price,...im painting engine bay,jams,and exterior
Old Apr 1, 2011 | 10:24 AM
(. )( .)'s Avatar
Default Re: eg9 getting painted..have questions plz chime in...
get the paint code. i know OEM paint cost around 50$ a gal
Old Apr 1, 2011 | 08:21 PM
hookedonponics's Avatar
HAHA oem paint is not 50 dollars a gallon....
depending on what brand you buy and where you buy it from the price will vary. Go and get a quote from a paint supply store.
Depending on weather you are priming the whole car or just spots that will also vary.
a eg is pretty small.
exterior - 7 - 12 oz for two coats base
jams - 4 - 8 oz two coats
bay - 4 - 8 oz for two coats
keep in mind this is just a estimate of material for just Base coat
say its already primed. go 2 coats base, 2-3 coats clear. also when you spray clear it tends to go crazy overspray and it seems to use more material for the same amount of work. if you are really into trying to save material cost down spray the clear at a lower pressure. you may get more orange peel in turn but it happens.
you WILL get a different price from everyone. opinions vary, if you want cheaper paint go with a tcpglobal restoration line or omni if you want something better go with ppg, sikkens.
Old Apr 3, 2011 | 02:25 PM
gorillafart's Avatar
i never heard of OEM paint
Old Apr 5, 2011 | 10:00 PM
(. )( .)'s Avatar
i pulled that price right off the net. i was looking for cypress green Pearl for my car, that's how much i seen it for
haha you know what i mean foolie
Old Apr 6, 2011 | 12:54 PM
haha don't trust paint that is 50 dollars. you may as well go use rustolem on the car for that price haha. if you want real paint go to a paint distributor and get a real brand. they sell it by the pint. you will regret using cheap paint, even if you do a amazing prep job.
slowesteg
17
Sep 7, 2013 05:51 PM
crxsir23
Paint and Body
Feb 24, 2010 06:12 PM
civic-8442-
Paint and Body
Aug 2, 2009 08:51 PM
choua01
Paint and Body
Feb 23, 2009 05:51 PM
firstgenrex
Sep 12, 2003 08:49 PM
