swapped front hub assembly from 89 hatch to 90 4 door, CANT FIND ROTORS THAT FIT!!
have a 89 dx hatch and my front left wheel bearing litterally fell apart and was making horendous noise, so went to my local pull a part and all the had were 4 doors, well i read that they were all the same 88-91, so i pulled a front hub minus the rotor off a 90 4 door, get it home it bolts up to everything fine, but my problem is, the new hub where the wheel studs are mounted too is bigger than the dx hub part its catching the lip in the back side of the rotor and i've tried 89 and 91 yr model rotors, however a 90 integra rotor fits but is too large and my caliper wont bolt back down, has anyone run across this problem??? im not stupid i used to own a four door i know for a fact it was a 90 four door, the door said it was made 3/90, but i cant find a freaking rotor!!!! please help!!!!!!!!
if the integra rotors fit. then you grabbed EX hubs. you need 90-91 EX or 90-93 integra calipers. im not sure if 94-01 are the same calipers. did the calipers on the HUBS you pulled have a metal bracket that surrounded the caliper/pads?
im almost positive they looked like this:
compare those to my old DX brakes:
coffin on wheels
Aug 14, 2007 07:23 AM
boxattack
Oct 12, 2005 08:07 AM
FULL-RACE EP3
May 16, 2004 08:31 PM
