Two levels for PS fluid?
Old Mar 27, 2011 | 03:24 PM
pityocamptes's Avatar
Default Two levels for PS fluid?
I have a leaking R&P so I am keeping an eye on it until I can get a new one. I noticed that the two lines on the outside of the can show it is within specs, yet when I take the top plug off the reservoir its kind of low. Hope that makes sense. Should I add ps fluid even though the level is equal to the outside can line, but when you look inside its low. Thanks!
Old Mar 27, 2011 | 04:41 PM
Default Re: Two levels for PS fluid?
Anyone?
Old Mar 27, 2011 | 04:43 PM
Former User's Avatar
I'm confused. Is the reservoir so dirty that you can't see the true fluid level?
Old Mar 27, 2011 | 04:57 PM
grumblemarc's Avatar
The Grumpiest
Is level or is the level NOT between the upper/lower?
Old Mar 28, 2011 | 07:04 PM
No, its clean but its like a thin wall sleeve (can inside a can) looking thing - reservoir. The outside shows its at the line but when you look straight down into the reservoir the fluid is lower than the outside line.
Old Mar 28, 2011 | 07:22 PM
Post pictures. Trust the fluid level you see inside the reservoir.
Canucksfan101
Feb 2, 2015 10:05 AM
adrw1
Apr 18, 2007 11:17 PM
redDAinteg
Jan 4, 2007 01:53 PM
93CamaroLT1
Jun 20, 2006 06:48 PM
..::91TEG-G2::..
Nov 15, 2004 05:35 PM
