What can you tell me about my CRX?
In my attempt to restore my crx to its pristine quality, I keep running into the same issue, which causes a huge issue when I need to mechanical things replaced as I know literally NOTHING about my crx. I cannot locate a vin decoder.
Vin: EF7-1100728
Also I need to start replacing some broken things like the glove box and the actual light shaft (shaft itself is cracked and turns when I turn my lights on).
My issues should be pretty obvious as I dont know if US crx parts are interchangeable due to the fact I am on the other side.
Thank you
Vin: EF7-1100728
Thank you
mrsqueak
Apr 5, 2004 03:29 PM
