B-Series Part Out. Skunk2-Darton-ACT-much more
Time to sell all of my B-Series stuff. I’ve been accumulating parts for the last year or so and I’m realizing it’s not the set up I really want. Most prices are pretty firm. I have tons of stock parts, so if you don’t see what you’re looking for, don’t be afraid to ask. I will be listing more and more things as time goes on. I will accept trades for DC2, AP1, K-Series parts, and legit wheels. Thanks for looking.
1. GSR B18C1 longblock. Unknown mileage, unknown condition. It rolls over just fine. The head has a crack in the back of it as seen in pictures, VTEC solenoid is damaged. The head could be fixed pretty easily. Comes with Skunk2 Cam Gears. $500
2. GSR Transmission. From the motor listed above (1). I was told the transmission had no grinds but I cant really vouch for it. There is a bolt broken off in the transmission where the linkage goes onto it. Priced accordingly. $300
3. B18B1 Block. Fresh 81.5mm bore. I would recommend a quick hone before use but it could be put together as is and be just fine. Crank has been balanced. What’s included: main caps, crank, oil pump, oil baffle, oil pick up. $300
4. B18C1 Head. 90k Miles. Everything looks very clean. Intake Manifold/Throttle body included. No cams. $350
5. Darton MID sleeves. Obviously never used. 81mm bore. $500
6. Eagle H Beam Rods (B18B). Were in a motor, cranked, but never ran. ARP bolts included. $250
7. ACT 6 Puck Race Clutch. Throw out and pilot bearing, pressure plate, disk. $350
8. ACT Streetlite Flywheel. $185
9. Innovative Mounts (Billet). Have been very lightly used. Red 70A bushings I believe. $240
10. Skunk2 Single Bend Short Throw. New. -sold to Fantastic420
11. Skunk2 VTEC solenoid cover. New. $20
12. Skunk2 68mm Throttle Body. Used lightly. All hardware and gaskets included. $200
13. Moroso Oil Pan. Plumbed for –AN return line. Like New condition. -sold
Garrett GT4082. Freshly rebuilt. T4 Divided Housing. .82 AR Hotside $600
15. UGR Standard Valves. New. $150
16. Prothane Shift Linkage bushings $15
would you happen to have the mounts and the mount brackets. I need both my block came without the brackets so i need all mounts and mount brackets. i so how much shipped to 76401, tx
