TN FS 90 Turboed CRX HF w/ 16G
Old Mar 27, 2011 | 09:20 AM
hedtrip's Avatar
Default FS 90 Turboed CRX HF w/ 16G
Name - Trip
Loc - Nashville TN
Price - 4k obo or Trade for Miata or bike
Contact - PM email H3dtrip@yahoo.com or Text call 901-288-5344
Ok Ive had this car for a about 5 & a half years or so & im just ready for something diff. Since I rarely drive it anymore, It was never really ment to be a DD. It weighed 1930 w me in the car so its super light & a blast to drive even at 8psi.
It has--
A built z6 block & stock z6 head
W/ Vitara low comp pistons approx 8:5.1
Tunertoys H-beam rods All new bearing, rings gaskets seals,water pump/ & belt. the build probably only has about 2500 miles on it.
16G Turbo from A evo 3 (not a cheap ebay one)
OBX turbo Mani
16g J pipe
FMIC & piping
550 cc injectors
Turbo XS rfl bov
Carbon fiber hood (just reclear coated it)
Rywire 0bd0 - 0bd1 harness
Rywire 0bd0 -0bd1 Dissy harness
Chipped p06 tuned w/ chrome
HX rims
Pilot stearing wheel
crx Si front hubs & brakes
DOD Racing seat
Front & rear upper strut bar
short throw shifter
Slight wire tuck
Striped rear interior
battery relocated to the back.
Built in Cage
the hatch shocks still work :headbang:
aftermarket clutch but i cant remember what brand. act i think?
Apexi turbo timer
new obx IACV
new Aluminum radiator
new speedway racing coolant reservoir
new radi FAN
new innovated lc1 wideband 02 & gauge
new fuel psi gauge
new oil feed line
new traction bar
new energy sway bar bushings
new energy moter mount inserts
new megan racing coilovers
new smocked out boost gauge
new smocked out water temp gauge
new jdm tight shift *** lol
new super long *** mirror
new oil change/spark plugs & thermostat
main relay was replaced a few months ago.
pretty sure Im forgetting something.
The Bad.
Its old Has alot of dings , scratches & paint isnt the best.
It needs a better tune it runs ok now just alot of back firing & is really rich
Needs A driver side window or needs fixed it has come unglued from its attachment points so if u role it down it comes off track. So i have it currently locked in the up position.
No heat Or AC
no carpet or rear interior
no Exhaust at all.
check engine light is on.
gay hood pins
ps seat has normal tears
door panels look like ****
the rear bars for the cage need to be welded in
some time the left turn signal blinks on the Gauge cluster for no reason? just started recently.
No clue on the Miles it doesn't have the Original Cluster it currently says 200k
im sure im still forgetting somthing
I have the car raised up right now so i can get in and out of the Garage
I would prefer to get cash or to trade somewhere local
Has a clean title
but I would allso really like a modded/clean Miata or maybe even a bike
thank you Trip
Old Mar 28, 2011 | 05:48 AM
hedtrip's Avatar
Default Re: FS 90 Turboed CRX HF w/ 16G
bump.
Old Mar 29, 2011 | 03:52 AM
hedtrip's Avatar
i guess this car isnt fan boy enough for this ****.
Old Mar 29, 2011 | 08:29 PM
srt4mike's Avatar
Bump for viewing.
N1ghtM0nkey
Jan 29, 2007 03:05 PM
ten_second_crx
Jul 31, 2006 01:39 PM
b16a2-t *turbocoupe*
Feb 18, 2006 10:25 PM
blackhbkid
Dec 19, 2005 07:39 PM
MeRexZC
Nov 30, 2005 01:04 PM
