ac blows hot while driving
Old Mar 27, 2011 | 06:01 AM
1sikhatch's Avatar
Default ac blows hot while driving
ok first off, i checked my system there is no leaks and there is fresh freon and it has the right amount. Now for the issue, if i start the car n let it idle the ac blows nice n cold but when i start to drive it gets hot, any help with this?
Old Mar 27, 2011 | 06:32 AM
Former User's Avatar
Default Re: ac blows hot while driving
Is the heater hose valve on the firewall stuck open?
Old Mar 27, 2011 | 07:00 AM
1sikhatch's Avatar
no its close,
also i just started my car n let it idle for about 5 mins n wen i came back the air was just blowing hot, so i turn off the car n start it back n the ac started to blow cold again until i start to drive
Old Mar 27, 2011 | 07:03 AM
When the A/C blows hot but is ON:
1) Does the condenser fan stop running?
2) Does the compressor clutch disengage?
3) Both (1) and (2)?
4) What car do you have?
Old Mar 27, 2011 | 07:42 AM
1sikhatch's Avatar
condensor fan stays on but compressor clutch disengage's, its a 99 dx
Old Mar 27, 2011 | 08:09 AM
boostedef123's Avatar
Probably have a relay issue or something electrical. Check your fuses and relays. Swap your horn with the ac relay if they are identical and see what it does.
Old Mar 27, 2011 | 08:30 AM
Most likely, the clearance between the pulley and armature plate is too wide:
Old Mar 27, 2011 | 08:44 AM
If the clearance is out of spec, these should help:
Old Mar 27, 2011 | 09:46 AM
hyperblu's Avatar
Are your lines freezing? My ford fusion did the same thing. My blower motor was going out...
Old Mar 27, 2011 | 09:49 AM
The A/C thermostat would prevent this^ in a Civic and the condenser fan would not run.
Old Mar 27, 2011 | 10:04 AM
hyperblu's Avatar
Thanks for clarifying ^^
Bobs2008Civic
Honda Civic (2006 - 2015)
13
Aug 9, 2017 05:33 AM
thinkskater007
Aug 28, 2012 07:56 PM
Pagley
Aug 8, 2009 07:15 AM
Gir
May 30, 2003 04:03 AM
