Gc/koni rear rattle
I replaced my pro kit to gc coilover kit on my h22 del sol,
The spring rattle when the car is lifted ,
I understand it is ok and normal but when riding on bumps
The rear spring sounds like it rattle and goes back to place.
Is this normal i saw on the net that I am not the only one.
Can I fix it ?
I am sure it is the spring
Please advice
Thanks
Can I fix it ?
Please advice
Thanks
How are you sure it's the spring? It's highly unlikely the spring is coming unseated unless the wheels are damn near leaving the ground as you go over bumps.
You been catchin' air or something? Dukes o Hazzard sweet jumps?
Can I fix it ?
Please advice
Thanks
Can I fix it ?
Please advice
Thanks
My endlinks hit the shocks on occasion, if the rear ARB has shifted too far to one side, making a nice rattle / clank sound when going over bumps.
everything is connected and tightened double checked, got oem sway bar and connected correctly, no adjustable end links, spring isolator installed.
it sounded like clank ,there is no way when riding fast on bumps that the spring will rattle?
before the installation i never heard something like that, maybe it was the exhaust or some metal moved in my trunk i will check and update.
Thanks
Thanks
redDAinteg
Sep 22, 2007 09:02 PM
95Sol
May 11, 2004 02:59 PM
