newbie w/ couple problems
hey guys i got a 95 ls 4door. its been lowered on megan racing coilover sleeves. the problem is i've had both cv axles replaced now and when stopped and hard turns it will start clanking and popping in the front like its got a busted cv joint. can i look at anything else? i dont know if it matter but the front camber is still off a little.
also last whats a good set of performance engine and tranny mounts? i got one that i suspect is broke and i wanna replace it with something a little better
its either the bushings on the coilovers wore out and the sleeve is shifting. or the cv axles where installed wrong. jack it up and grab the sleeve if you can move it with ur hand the bushings in the sleeve are bad. Camber shouldnt really be an issue. if your mounts arent blown out energy suspension makes an insert kit.
Ok thanks. I think ive narrowed the popping to the drivers side. Ill try and research them energy suspension mounts. I seen some "torque mounts" on ebay. Made out of alum with poly inserts. Anyone use them?
