need help dont know what it is fuel spark wiring
Old Mar 26, 2011 | 09:48 PM
N'viouzEF9's Avatar
Default need help dont know what it is fuel spark wiring
ok so my car needed a new jumper harness so i ordered one and it was a lil different so i had to make it work and make sure wires were going to the right thing well anyways i tryed starting it after i put it on and it turned on really ruff and it was throwing out black smoke n smelled like gas so i assume running rich i let it idle well at least try and it would just die out so i tryed starting it again and it just starts up then dies ahh its just like problem after problem and idk what to do now fyi the cars a 88 dx hatch wired obd1 with a d15b7 i have the d15b7 dizzy to and i just checked and i was running a obd1 pr3 ecu yikes! wrong ecu but thats all i had but it was running ok b4 i changed the jumper harness it was kind bogged and pulled a lil but im pretty sure thats because the wrong ecu so what do i do now the dizzy is brand new u guys think it messed up? i really need to fix it asap for work or ill be screwed lol i also have a new main relay a new igntion switch any help apprecated
Old Mar 27, 2011 | 05:45 AM
tonythetuner®'s Avatar
Default Re: need help dont know what it is fuel spark wiring
Any cel??? If so wat codes are you throwing. "And wat kindda jumper harness did you get that You had to fix to make work"?
Old Mar 27, 2011 | 01:11 PM
Laserjock's Avatar
Ok, slow down speedy and retype this with some punctuation and seperate into paragraphs so it is easier to read. If you want help, make our jobs easier and you'll get faster results. I got a headache from trying to read your post.
88_hatch_ls
61
Aug 1, 2013 08:44 PM
Fuzzy Rhubarb
Jan 25, 2010 10:16 AM
xsi90teg
Feb 17, 2009 04:31 PM
ZChatch90
Feb 11, 2006 11:40 AM
Turbo88hatch
May 17, 2005 06:54 PM
