Any tips on how to fix this back seat pin (pics)? 98 dx
Old Mar 26, 2011 | 08:01 PM
Nooch's Avatar
Default Any tips on how to fix this back seat pin (pics)? 98 dx
For once it's not the engine hood latch
Before I crack into the back of the seat and destroy something I'd just like to know if anyone has had to fix this before? If so, how?
Sorry for the blurry pictures, I only had a chance to take the pictures while I was in the car being driven >.>
Old Mar 26, 2011 | 09:39 PM
Tmklim's Avatar
Default Re: Any tips on how to fix this lever? 98 dx
Wow bro that sucks I'm sorry.I've taken my seats in and out a few times.I know the bottom tail lifts to expose bolts but I don't recall a zipper but I do recall hooks.I'd take it to your nearest upholsty shop and get then to unhook the covers and I'm sure they can fix it.if not Honda or alldata should be able to pull up an explosion so u can see what needs to be done to correct the issue.good luck
Old Mar 26, 2011 | 11:55 PM
90efzc's Avatar
ahh fuc...
Old Mar 27, 2011 | 01:12 AM
98civdx's Avatar
Master Detailer
I belive they are called "hog rings" Those are holding the cloth cover down.
If you pull the seat, and pull the back cover off of them you should see the rings holding it down. Break, cut or something, the rings should come off. And you should be able to pull the cloth off.
To put it back on you will need to buy the hog ring tool, and hog rings. They shouldn't cost to much.
Old Mar 27, 2011 | 01:15 AM
Need_jdm's Avatar
get a new back seat
Old Mar 27, 2011 | 11:44 AM
90efzc's Avatar
Originally Posted by Need_jdm
get a new back seat
ahh, no.
Thank you, I'll check it out.
Old Mar 27, 2011 | 02:14 PM
BWFL's Avatar
Default Re: Any tips on how to fix this back seat pin (pics)? 98 dx
I did this too.
The peice your holding just twists onto a metal kind of lever. get a flash light and a small screwdriver, look in the hole and find this metal peice use the screwdriver to move it into the middle and pop the plastic peice right back on. worked ever since. this way you don't have to take seat off or anything.
Old Mar 27, 2011 | 02:16 PM
BWFL's Avatar
I don't remember if the plastic peice twists on or not look on the inside of it and look for threading.
Old Mar 27, 2011 | 03:00 PM
95b18c1egcoupe's Avatar
i fixed this on an eg and the plastic piece just screwed onto a metal rod in the seat like BWFL said you dont have to take anything apart
anoble1
Feb 10, 2017 08:10 AM
civic402lx
Sep 30, 2016 10:12 AM
shnukems1
Jun 26, 2008 12:04 PM
Lshatchy91
Mar 19, 2004 05:09 PM
meanm3
Mar 29, 2002 05:12 PM
