Lower Ball Joints -Pressed-in or Snap Ring
Old Mar 26, 2011 | 05:46 PM
ericbr's Avatar
Default Lower Ball Joints -Pressed-in or Snap Ring
Hello all,
First post for this long time Honda owner. The vehicle is a 2000 Accord Coupe 4cyl. I recently replaced the right front lower ball joint with one from NAPA. The one they gave me was a press fit version. I have already installed it but I noticed the factory one on the left is a snap ring version. The left lower ball joint needs to be replaced. The question to the board is:
Should I try track down another snap ring version and then replace the one on the right? Or is the pressed in versions adequate for a daily driver?
thanks in advance for the repsonses.
Old Mar 26, 2011 | 06:30 PM
97civic000's Avatar
Default Re: Lower Ball Joints -Pressed-in or Snap Ring
i did my lower ball joints in my 93 and they are pressed in and then have a snap ring. the first set i got was for a civic and was considerably smaller and they told me that they would work for my accord. so i went to napa and got the correct ones pressed it in and added the snap ring.. any way the snap ring is for safety for u and other drivers. so id recommend it..
Old Mar 27, 2011 | 07:17 AM
ian1006's Avatar
I would get one with a snap ring, just did my uppers and think its a good idea for a safety
culprit00
May 16, 2014 11:21 AM
HONDAPARTSMANMIKE
17
Sep 29, 2010 04:14 PM
Digitalsmoke
Aug 14, 2009 08:57 PM
B18EG6
10
Jan 23, 2006 03:20 PM
tom991
Mar 30, 2004 04:40 AM
