Suspension & Brakes Theory, alignment, spring rates....
KoniGC or Eibach prokit
Old Mar 26, 2011 | 05:11 AM
CaP's Avatar
CaP
Default KoniGC or Eibach prokit
hi hondatech
i have an 97 LS with stock suspension,
I have looked into a lot of different set ups. lets start off
Koni + GC
Eibach Prokit
Or BC racing Coils
daily driven, dont want to be slammed
Old Mar 26, 2011 | 05:16 AM
hondam's Avatar
Default Re: KoniGC or Eibach prokit
if you want daily driven,and dont want to be slammed stay with the eibach prokit drop only 1.5" going lower than that you going to need camber kit and a good aligment
Old Mar 26, 2011 | 06:03 AM
CaP's Avatar
CaP
PRO-KIT + PRO-DAMPER = PRO-SYSTEM
EIBACH Part Number: 4020.780
1.3inch drop
http://cgi.ebay.com/ebaymotors/Eibac...Q5fAccessories
is this kit bang for buck? by any chance?
or what about this coil?
PROGRESS (CS-II)
94-01 Acura Integra Coil-over kit (350/250)
Part #: 77.1003
Old Mar 26, 2011 | 06:09 PM
PreyStayShun's Avatar
Eibach pro-system doesn't compare to Koni/GC...thats two different worlds away man.
Koni/GC is the best sub $1000 suspension you can get IMO. And most will say the same.
If I HAD to choose a spring/strut combo the prosystem or tein h. tech/koni str.t would be the way to go.
Old Mar 27, 2011 | 09:52 AM
94eg!'s Avatar
#1 Super Guy
Loved
I've got a 94 Civic (same suspension as Integra) with Koni/GC. It's lowered about 2.5" to 2.75" without camber kits. Camber in the front is -2* to -2.5* and rear is -1* to -1.5*. This is perfectly fine on any daily driver and can be found on lots of performance cars. As long as you get the toe zeroed out, the tires will last their full life. I've got Falken RT615 that have been on since about the time they first came out. No problems with uneven tire wear. The fronts will wear the insides a little more if you do burn outs, but I don't do that.
As long as you like to do a little hard cornering here and there, you won't have any troubles whatsoever.
PS: Sears does hassle free alignments on modified cars. They even knew to add some extra boards to get the front lip to clear the ramps. They get a from me...
Old Mar 27, 2011 | 11:29 AM
odie88's Avatar
koni/gc for the win
Old Mar 27, 2011 | 04:54 PM
wanabgts's Avatar
Agreed the koni/gc setup will be miles ahead of the of the eibach in performance and have a good ride as well as long as you are conservative on the spring rates.
Koni yellow is the best available box-stock shock on the market in my oppinion, and have seen many poeple take of their 1000+ dollar coilovers in favor of them.
Zack
93CivicSI
Oct 2, 2003 06:53 AM
B18CYAAA
Jun 30, 2003 09:27 PM
grizoove
May 7, 2003 01:04 AM
B18C_eg
Sep 27, 2002 04:35 PM
Gen5_EG
Nov 7, 2001 09:21 AM
