b20z type R cam clearances
Old Mar 25, 2011 | 05:30 PM
HOM DON's Avatar
Default b20z type R cam clearances
So after doing a bit of research, I have found a few things that people have said about B20z pistons and Type R cams. To be specific, I'm building a b20b4 with b20z pistons, pr3-1 head with 98 spec type R cams
Things that people said
1)You will need to grind valve reliefs on pistons to clear valves
2)The valves will clear but you have to have cam timing set to 0 degrees
3)Cam timing can be adjusted 4 degreesą
I was just wondering if anyone had any experiences with the similar or even the same set up as mine.
Thanks!
Old Mar 26, 2011 | 04:53 AM
hondam's Avatar
Default Re: b20z type R cam clearances
I think Im not sure , but the only head that it will give valve clearence problems is the p72 gsr head
Old Mar 26, 2011 | 12:37 PM
mouab18c1's Avatar
You shouldn't even have any clearance issues with stock parts!
Old Apr 8, 2011 | 07:28 PM
HOM DON's Avatar
bump
Old Apr 9, 2011 | 04:32 PM
1998GsRIntegra's Avatar
I hope thats sarcasm. Lol
Old Apr 9, 2011 | 11:23 PM
Blaze45's Avatar
Brrraaaap!
There are more then likely people who have the same setup you have. The search function is outstanding on this website and has helped me out of a jam more then a few times.
The safest way to find out if your going to have clarence issues is to clay the pistons and then install the head. Remove the head and go from there... I myself am not sure of the proper procedure of how to accomplish this task but a simple search should point you in the right direction.
Old Apr 10, 2011 | 11:39 AM
mouab18c1's Avatar
Nope!
Old Apr 10, 2011 | 05:32 PM
Nope!
You do know valve reliefs on non-vtec pistons are smaller than those on vtec motor pistons. Right? If your joking its hard to understand over the internet...
Old Apr 10, 2011 | 09:23 PM
mouab18c1's Avatar
That's why you tune it and keep it within a safe rev limit. Numerous stock parts ls vtec builds have been done. I myself had a b20vtec. Had no issue what so ever. If he's worried then clay the motor.
Old Apr 10, 2011 | 09:31 PM
B20vEf9's Avatar
From my understanding with b20z pistons and ITR cams they need to be left at 0,0.
Old Apr 10, 2011 | 10:27 PM
mouab18c1's Avatar
I don't see the benefit of cam timing with stock cams. 0,0 would be best.
97twodoor
11
Jun 5, 2009 03:40 PM
b20powereDA
Jun 21, 2007 04:40 PM
blues2k3
Apr 21, 2006 03:57 AM
T_bones
Oct 11, 2005 10:16 PM
BlueTeg
Jan 25, 2004 04:01 PM
